Bios file and Bios related issue.
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    what are power bios and graphics bios? which one should write.
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    Re: Bios file and Bios related issue.
    any expert in bios related issue?
    • tomodachi
      • Apr 2012
      • 608
      • Turkey
      As far as I know there are only two BIOS on new generation motherboards. One for system and other for keyboard controller (I/O chip)
      • dj_ricoh
        • 2073
        I don't understand nothing what you write.
        Don't use Google translate or use it wisely .
        Now to the problem you have .
        Video BIOS ? In notebook? I don't think so.
        'Maybe in PC, but its so-8 so you can take it out.video cards do have firmware.
        In notebook BIOS ye do manage power I saw many time of a corrupt BIOS.
        My last post with t410 was opposite, it was chip set that needed reflow
        Good luck
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          Good luck
          i can't get your writeup mr. dj_ricoh. can you please brief a bit about notebook bios of some latest notebooks (if you really know)?
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
