HP Elitebook 645 G10 BAD BIOS
  • bcrsr
    • Jun 2018
    • 35
    • United Kingdom
    Hi. I had someone from ebay try to remove computrace from this laptop but now I just get flashing caps light (6,1). I have attached a backup bin here if someone would be willing to have a look.
    Device - HP Elitebook 645 G10
    Thanks in advance for and help.
    • 22236
    Re: HP Elitebook 645 G10 BAD BIOS
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • bcrsr
      • Jun 2018
      • 35
      • United Kingdom
      Sorry..
      I have added the serial number and board number here.
      S/N - 5CD324KFYV
      BOARD - DA0X9TMB8D1 REV D
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        Sorry..
        S/N - 5CD324KFYV
        you backup bin is likely corrupted also
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Sorry..
          S/N - 5CD324KFYV
          TRY A NEW ONE
          • bcrsr
            • Jun 2018
            • 35
            • United Kingdom
            Sorry for the late reply. This did not work either. Still have flashing caps. Thanks for your help.
            • hoaca388
              hoaca388 commented
              Editing a comment
              There are 2 files: Bios and Ec.
            • bcrsr
              bcrsr commented
              Editing a comment
              Should I upload both files? Honestly, I am a bit out of date with all of this. Only really worked with BIOS file. Thanks.
            • hoaca388
              hoaca388 commented
              Editing a comment
              Yes, you can try
          • RWS93
            • Apr 2021
            • 16
            • United Kingdom
            Hi, have you ever managed to get this one sorted? I am having a strange case with this laptop. So there was a BIOS password on it. I attempted to remove it by flashing the chip with the .bin provided above "HP EliteBook 645 G10_new_4MATIC.rar". I have also managed to get just blinking capslock. I have loaded back my original bios image and I still get flashing capslock. Machine has been booting just fine before. I have only taken off the chip to program it. No components have been knocked off or anything like this. I am 100% certain I have loaded the origina image back. Still just a flashing capslock. 3V and 5V are on. Rest of the voltages comes on for a sec and then off. Capslock is flashing 7 times. How it is not working with the original image back on the chip? How is that possible... Anyone having any experience with this device?
            • RWS93
              • Apr 2021
              • 16
              • United Kingdom
              I am having problems with the following laptop:
              Brand: HP
              Model: Elitebook 645 G10
              Motherboard model: DA0X9TMB8D1 REV: D
              It is an AMD 7000 series CPU laptop.
              The problem is this: computer has came with BIOS password and also Windows locked to a company domain. I have done what I would normally do in such case:
              1. Desoldered BIOS chip
              2. Put it into the programmer
              3. Made two .bin backups of original bios
              4. I found a fresh BIOS image on the internet
              5. Write the new fresh BIOS image to the machine
              After I have done this the machine would not boot. It starts automatically when power is plugged in then:
              1. F5 key LED lights up Orange
              2. Power LED flashes White/Orange
              3. Machine turns on and off like this a few times
              4. Finally the F5 key LED turns off and the Power LED stays white
              5. If I press power button in such condition I get 7 flashes on the CapsLock LED
              6. Laptop reacts to the power button: if I press it long enough the machine turns off but then turns ON automatically and the cycle repeats
              Under such condition I can see voltages on the motherboard going up: 3.3v, 5v are ON all the time. For a second or two I do get 1.8v for RAM and one of the CPU power stages (the high resistance one) goes up to 0.8v. Later these voltages go down and only 3.3v and 5v remain ON.
              I thought this was just a corrupted image I downloaded from the internet. So I written back the original image. After soldering the chip back to the laptop I still get the same issues as described above. Power light flashing white / orange, Caps Lock LED flashing 7 times. Same voltages on the board.
              I have checked the BIOS chip few times and it is programming and verifying fine each time. The soldering is done right: chip is always soldered back correctly with all the pins making contact. No components has been blowed off the board with hot air. Soldering has been done very carefully. I do not think my original BIOS would be corrupted. It has been read on two different computers but using same programmer (I have made two copies).
              What could be the problem? I have seen on another forum someone having simillar problems with G8 and repaired by flashing the EC ROM.
              I have attached both images of BIOS and EC ROM.
              Could anyone please help?
              • danito
                • Jun 2016
                • 1233
                • Romania
                try
                • RWS93
                  • Apr 2021
                  • 16
                  • United Kingdom
                  Originally posted by danito
                  try
                  Thank you very much for preparing this image for me. It seems like it is bigger than the original .bin: 32.769 KB (your image) vs 32.768 KB (original image). Maybe the difference is in the first bytes of the file as I showed in the screenshot?
                  • RWS93
                    • Apr 2021
                    • 16
                    • United Kingdom
                    Ah I think I understand now. Is it the security register? In AsProgrammer it does not show after I detect the chip... but in NeoProgrammer it does. It is called "security register1". It is exactly of the size 1KB - the extra data at the beginning of your BIOS you prepared for me. Hmmm maybe I just used AsProgrammer initially to work with this laptop and erased the whole chip including the security register. But when making a backup it did not read the security register as my original images are only 32 768KB? Later I wrote just the backup 32 768KB leaving the security register empty? And this is why it won't boot? Hmmm... I took that 1KB of the BIOS you provided and wrote it to the "security register" of the chip. Now the main BIOS image goes in the 32 768KB part. Will see... hopefully this will sort the issue. I think it is quite a logical reasoning here.
                    • RWS93
                      • Apr 2021
                      • 16
                      • United Kingdom
                      OK so I am an absolute idiot. I do hot air soldering very often but turns out this time I made a mistake. I allowed the idea for this in my head and I started thinking I could knock a component off. I could not find a schematic or board view but I found HP YT channel where they are posting maintenance videos about their machines. There was a picture of the motherboard. On this picture ROM is installed in some sort of a socket unlike on my board where it is soldered but everything else is the same. I noticed I must have knocked off a resistor when desoldering the chip. This resistor has been connected to pin 1 of the ROM. I found that on the other side of the track the voltage goes up to 3.3V max so I decided to replace the resistor with a soldered bridge. After doing so on original BIOS picture laptop wakes up. Keyboard backlight turns ON, power LED turns ON, all the voltages on the board are present, CPU getting warm but no display backlight and no picture. After about 10 sec the machine restarts.
                      I guess the bridge is not enough and replacing that resistor is essential. There is no board view no schematic so I do not know the value of the resistor. I found schematics for other laptops with similar ROM and design with the resistor connected to pin 1. Normally these resistors are within 22 - 220 ohm. I will give it a go later today. Any other ideas on the resistor value? Thank you.
                      • RWS93
                        • Apr 2021
                        • 16
                        • United Kingdom
                        Ok sorted. 22ohm resistor worked fine. Machine runs on original BIOS. I will later try the BIOS provided above to unlock it.
                        • Muhammad Faizan
                          • Mar 2022
                          • 32
                          • 000
                          hi master
                          This is my HP EliteBook 655 G10 in bios password can any one unlock my laptop?
                        • alfredposadas09
                          • Aug 2020
                          • 342
                          • Philippines
                          Originally posted by Muhammad Faizan
                          hi master
                          just flash the winbond dont touch the gigadevice
                          • Muhammad Faizan
                            • Mar 2022
                            • 32
                            • 000
                            ok tomorrow i will check and update you
                            • Muhammad Faizan
                              • Mar 2022
                              • 32
                              • 000
                              After all I enter in th bios why password appear again how
                              • alfredposadas09
                                • Aug 2020
                                • 342
                                • Philippines
                                after flash first boot go to bios press f10 then reset default settings.. if u don't do this the password will not be remove
                                • alfredposadas09
                                  • Aug 2020
                                  • 342
                                  • Philippines
                                  flash it again and follow this steps
                                    SMDFlea commented
                                    Editing a comment
                                    Please do not offer any help to members if they have not posted the serial number
                                • shiriff47
                                  • May 2018
                                  • 45
                                  • Algeria
                                  Can anyone help me to unlock hp EliteBook 645 G10
                                  motherboard : DA0X9TMB8D1 REV D
                                  S/N : 5CD351K5LJ
                                  • Wutru
                                    HP Elitebook 820 G4 BIOS repair assistance required
                                    by Wutru
                                    Hi guys,
                                    If someone would be able to provide some expertise, I'd be very grateful.
                                    BIOS Corruption - Cause
                                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                    09-06-2025, 10:32 AM
                                  • STKR123
                                    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                    by STKR123
                                    Greetings badcaps community,
                                    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                    I learned that desoldering...
                                    10-29-2024, 06:03 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Guest
                                    Elitebook 850 G5 BIOS bricked
                                    by Guest
                                    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                    I assume the BIOS update failed, so I searched for the BIOS chip.
                                    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                    Can the corrupted...
                                    03-24-2025, 01:21 AM
                                  • cr4zychriss
                                    by cr4zychriss
                                    • Rebrand: PC Specialist
                                    11-14-2025, 04:04 PM
