Razer rz09-02386 dead after battery change
  • vicentemj
    • Jul 2016
    • 6
    • mexico
    I already flashed main bios 16mb from official site without success, my laptops has every normal voltaje that i can measure and i think the 8mb bios is corrupted.
    C1_MB PVT V3.0 20180315 GTX 1070
    I look for a dump or if anyone can look for my backups (16mb and 8mb)
    thanks
  • vicentemj
    • Jul 2016
    • 6
    • mexico
    Re: Razer rz09-02386 dead after battery change
    I attached 3 bios files from my laptop, would someone check them please, i openened them using uefitool and he main one looks ok compared to the one downloaded from razer support site
    thanks and best regards
      • 22182
      The one at the support site will be different,as it has clean ME firmware (configured) it hasn`t been booted and initialised.The bios region code will be different as well if its an updated version.
      Your problem started with the battery,does it boot without the new battery,does it start with the old battery.
      • vicentemj
        • Jul 2016
        • 6
        • mexico
        it no longers boots, does not start at all, i only see voltaje on power button, around bios 3.3v no heat or short that i'm aware of
        • vicentemj
          • Jul 2016
          • 6
          • mexico
          can anyone look at my bios dumps? i'm looking for currupt data or something
          • minhdigital
            • Nov 2022
            • 765
            • Vietnam
            Sent to you, Try
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • huzo
              HP ELITE X2 1013 G3 weird battery issue
              by huzo
              Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
              01-31-2025, 12:09 AM
            • trepachka
              iPad Air A1475 Boot loops after replacing battery
              by trepachka
              This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
              The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
              I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
              11-08-2024, 03:17 PM
