HP Probook 635 Aero G7 Endpoint Security Controller Problem
  • alfredodinolfo
    • 128
    • N/A
    ProdID: 2W8R7EA#ABZ
    SN: 5CG10171VK
    mb code: LINDEN 6050A3147201-MB-A01
    Thank you
    Last edited by SMDFlea; 11-09-2023, 11:07 AM. Reason: Added "635 Aero" to thread title.
    • 21869
    Re: HP Probook 835 G7 Endpoint Security Controller Problem
    Originally posted by alfredodinolfo
    mb code LINDEN 6050A3147201-MB-A01
    Thank you
    Read the updated rules,you must post the laptop serial number
    • alfredodinolfo
      • 128
      • N/A
      Sorry
      • hoaca388
        Badcaps
        • Jan 2022
        • 12328
        Sorry
        HP ProBook 635 Aero G7 Notebook PC (182W0AV)
        • alfredodinolfo
          • 128
          • N/A
          work thank you
          • alfredodinolfo
            • 128
            • N/A
            sorry, now no end point but is in MPM mode and no serial on bios information. I tried to write with HP BIOS Configuration Utility sp143621.exe but no chance to write information sn etc.
            can you help me?
            • Matteo Setti
              • Apr 2024
              • 12
              • Italia
              Hi, I have a problem with the "endpoint security controller problem" error.
              Can someone help me?
              I am attaching the Bios file in the attachment
              SN# 5CG10171CO
              • dgs3342
                • May 2017
                • 36
                • Italia
                works fine! Thank you
                • Matteo Setti
                  • Apr 2024
                  • 12
                  • Italia
                  Hi, can I also use the bios reported by hoaca388 in post #4? Do I need to do any work after flashing the chips?
                  • Matteo Setti
                    • Apr 2024
                    • 12
                    • Italia
                    Hi, I dumped bios and EC.
                    SN# 5CG10171CO​
                    • alfredposadas09
                      • Aug 2020
                      • 342
                      • Philippines
                      SN# 5CG10171CO​
                      there is a problem in ur file
                      • Matteo Setti
                        • Apr 2024
                        • 12
                        • Italia
                        Are these ok ?
                        • alfredposadas09
                          • Aug 2020
                          • 342
                          • Philippines
                          Are these ok ?
                          just program u368
                          first boot press f10 go to bios setup and reset the settings to default
                          • Matteo Setti
                            • Apr 2024
                            • 12
                            • Italia
                            It doesn't work, the caps lock led flashes 7 times, as it did before
                            • Matteo Setti
                              • Apr 2024
                              • 12
                              • Italia
                              I have no idea if this could be a problem, I noticed that the SN# code is 5CG10171C0 and not SN# 5CG10171CO, With the final zero and not with the O
                              • Matteo Setti
                                • Apr 2024
                                • 12
                                • Italia
                                Any suggestions?
                                • Matteo Setti
                                  • Apr 2024
                                  • 12
                                  • Italia
                                  Hi, I tried to update the bios of u368 as suggested by alfredposadas09 in post 13, but without success. The Probook Aero 635 G7 doesn't start and flashes 7 times. I think the EC firmware is also corrupt. Anyone have any suggestions?
                                  I suspect that the EC firmware is corrupt because the first bytes are set to 00 instead of FF as the ECs I see usually are. See post #12​
                                  • alfredposadas09
                                    • Aug 2020
                                    • 342
                                    • Philippines
                                    just put back the original firmware and the laptop will start again
                                    • Matteo Setti
                                      • Apr 2024
                                      • 12
                                      • Italia
                                      actually no, because with the old firmwares the HP Probook only rarely started and the few times it started it showed the controller problem. I'm thinking of a more drastic solution by changing bios and ec, but I don't know how to do it
                                      • alfredposadas09
                                        • Aug 2020
                                        • 342
                                        • Philippines
                                        try this .. make sure u dont switch the bios chips otherwise it wont work
                                        • fede77
                                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                          by fede77
                                          Notebook HP ProBook 450 G8
                                          ProdID 2K8L1LT#AC8
                                          Mother: DAX8QAMB8D0 REV D
                                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                          03-10-2025, 07:12 AM
                                        • jmp9155
                                          i have hp probook 640 g4 stucks hp endpoint security controller
                                          by jmp9155
                                          accidentally after the upgrade to 1.28 suddenbly my i hp probook 640 g4 stucks hp endpoint security controller i already downgrade the bios to 1.15 still the same and again revert back to 1.28.
                                          any solution for this issue?
                                          07-09-2024, 06:23 AM
                                        • kolebbk
                                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                          by kolebbk
                                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                          HP Endpoint Security Controller problem
                                          there is a problem with the hp endpoint security controller on the unit
                                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                          09-04-2024, 12:44 AM
                                        • mego1974
                                          HP Probook x360 435 G7 Endpoint Security Controller
                                          by mego1974
                                          Hello
                                          i need help
                                          I have a laptop HP Probook x360 435 G7 with bios password
                                          I succed to remove the password with the RC toll and right now i have this mesage on the scren "HP Endpoint Security Controller Problem " "Please contact the HP.Inc to have the unit serviced".
                                          I have read the both bios chips and i have posted a picture with the chips pozition.
                                          Can anybody help me with intruction or look on the dump if something is wrong ?
                                          Thanks in advance!!
                                          Edit
                                          Serial 5CG03947C4...
                                          12-17-2023, 01:57 PM
                                        • spider300
                                          HP ProBook 430 G8 hp endpoint security controller problem
                                          by spider300
                                          please Help Me ... ProBook 430 G8
                                          HP EndPoint Security Controller Problem...
                                          07-11-2023, 08:40 AM
