Rog Strix G512LW-ES76 BIOS help
  • Fabregasronaldsr
    • Jan 2015
    • 15
    • Philippines
    I need assistance in resolving issues with an ASUS ROG Strix laptop, specifically the model GL512LW-ES76. The laptop was taken to another repair shop, but they failed to back up the original BIOS file. After replacing the PCH and reprogramming the BIOS using the provided file, I am experiencing problems with the LAN, video card, and Wi-Fi functionalities. Could someone please help me rectify the BIOS file to resolve this issue? I am facing a dilemma as I do not possess the original BIN file.
    Model: G512LW-ES76
    Board Model: G532LWS R1.3
    SN: LANRKD02394842B
    Specs: Intel Core i7-10750H, RTX2070, 15.6 240hz
  • hoaca388
    Badcaps
    • Jan 2022
    • 11886
    Re: Rog Strix G512LW-ES76 BIOS help
    Model: G512LW-ES76
    SN: LANRKD02394842B
    Try
    • Fabregasronaldsr
      • Jan 2015
      • 15
      • Philippines
      Thanks hoaca388, tried your Bin file, NO Display
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        Model: G512LW-ES76
        SN: LANRKD02394842B
        your posted bios is original and dmi match with that bios
        and it was clean and configured already
        BTW i try to fix it you may try
        • Fabregasronaldsr
          • Jan 2015
          • 15
          • Philippines
          Thanks @qayyum786, still the same Error in graphics and wifi card
          is it possible that the problem still in PCH or bad/cold solder?
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            because some one play already in bios before you so i think bios still could be an issue
            before you touch PCH
            you may try another bios file rather than original (third party bios from other laptop) if still no luck than only fall in to a hardwear
            • Fabregasronaldsr
              • Jan 2015
              • 15
              • Philippines
              Update: after replacing new PCH again and using your bios @gayyum786, All device working properly now! thanks all!
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                glad to hear that
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
                • Fr33man
                  BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                  by Fr33man
                  I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                  *Novo button power on
                  *Disconnected internal battery...
                  09-23-2024, 01:16 PM
