Need Bios for HP Notebook - 15s-du1079tx
  • crystalsercpn
    • Jul 2013
    • 14
    • india
    Dear friends I need cleaned bios file for HP Notebook - 15s-du1079tx
    I am attaching old Bios backup file here.
    Thanks for your help and support.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Need Bios for HP Notebook - 15s-du1079tx
    Serial number ?
    • crystalsercpn
      • Jul 2013
      • 14
      • india
      Originally posted by hoaca388
      Serial number ?
      Hello
      Sn-cnd0370vyh
      Laptop Model HP - 2b5v6pa#acj
      • peste
        • 13924
        • ROMANIA
        Hello
        Sn-cnd0370vyh
        https://www.badcaps.net/forum/showth...ighlight=085F1
        try the bios from post #2 ...085F1
        • crystalsercpn
          • Jul 2013
          • 14
          • india
          Thanks for your support ��
          I will check and update you.
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • Sebastian Codrean
            BIOS file for ASUS F542UN laptop
            by Sebastian Codrean
            Hello to all of you! I need help with a BIOS file.
            The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
            So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
            02-20-2025, 10:25 AM
