Dell LA-K034P NO AUDIO
  • arif3203
    • Feb 2021
    • 55
    • Banyumas
    Help This Problem Dell LA-K034P
    Service Tag:8VTRPH3
    Problem no Sound
    Thank you
  • hoaca388
    Badcaps
    • Jan 2022
    • 11871
    Re: Dell LA-K034P NO AUDIO
    Service Tag:8VTRPH3
    Problem no Sound
    Thank you
    Vostro 3400
    Service Tag: 8VTRPH3
    • chh0596
      • Sep 2023
      • 10
      • 中国
      This problem requires redoing the CPU
      • arif3203
        • Feb 2021
        • 55
        • Banyumas
        Originally posted by hoaca388
        Vostro 3400
        thank you i"can try
        Thank you for the information
        Vostro 3400
        same problem no sound
        • kingstonalumni
          • Oct 2023
          • 17
          • VIETNAM
          Dell vostro 3400. GDI4A LA-K034P REV:1.0
          ST: BM293G3
          Plz help! No sound detect. tks all​
          • hema1414
            • Dec 2014
            • 15
            • india
            LA-K034P no audio
            ST:1ZQSYM3
            • LBTT1121
              • Nov 2024
              • 593
              • Việt Nam
              Originally posted by hema1414
              LA-K034P no audio
              ST:1ZQSYM3
              • samson7point1@yahoo.com
                Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                by samson7point1@yahoo.com
                The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                The player processes the audio signal using two different reference frequencies. The "R"...
                04-30-2024, 11:22 AM
              • falcontech
                MOTU TRAVELER MK3 AUDIO PROBLEM
                by falcontech
                Good Afternoon
                I have a problem with this MOTU audio card, a traveler MK3, the connection to the computer is via firewire, the card is recognized by the computer (both mac and win) but I have no audio output, on the front there are a series of LEDs including the clock (44.1, 48, etc.) and that LED at the time of connection usually remains fixed telling me the clock frequency set on the computer, now at every start the LED in question remains flashing in most cases, sometimes it becomes fixed, other times it disappears, without any sign of operation, I exclude problems with the firewire chip,...
                01-24-2025, 08:47 AM
              • toti24
                (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                by toti24
                dell precision m4600 laptop
                i7 2760qm
                8gb ram 750gb HDD
                intel hd 3000 integraded and nvidia quadro 2000m
                pleasea bear with me english isnt my language and ill try to be as clear as possible
                note i live in mexico in a very small town..
                thank you.
                laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                the brick happened when i was installing win 10 using usb.
                used rufus and officia microsoft.iso
                it finished copying files from usb...
                03-06-2022, 08:39 PM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
              • Achille15
                Dell N5110 problem
                by Achille15
                so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                03-29-2025, 04:41 PM
