latitude 5440 la-m401p la-m402p password
  • imedbox
    • Jun 2022
    • 11
    • Algérie
    #201
    Originally posted by shiyab
    hi try
    Thaks you i will try it and give back the result.
    • Thoa
      • Jun 2025
      • 28
      Hello Community.
      I have here a Dell Latitude 5440
      IBD40 LA-M401P
      Rev: 1.0 (A00)
      ST: DZRJGY3
      I tryed to get a binary file of the 6x8 first and opened in UEFI-Tool. It does not look like an valid bios file. I used NeoProgrammer with W25Q256FV. When i open a file posted by a member, i can see all the modules in UEFI Tool
      EDIT
      Ive read the IC twice and compared the files, which are identically
      EDIT2:
      just recognized the files are completely empty
      looks like the pogo-pin-tool does not work here. the solder-dots are really much smaller than on the Latitude 5520
      • hoaca388
        Badcaps
        • Jan 2022
        • 12262
        #203
        Originally posted by Thoa
        Hello Community.
        IBD40 LA-M401P
        Rev: 1.0 (A00)
        ST: DZRJGY3
        EDIT
        EDIT2:
        Read the IC at least 3 times and compare them with each other.
        • Thoa
          • Jun 2025
          • 28
          Thanx for your fast reply hoaca388.
          I bought another pin-connector, same result. I do not get any data. It seems that NeoProgrammer reads data, when finished, it says success. But it is only FFFFFFFFFFFFFFF
          Do I have to do the 3.3V-modification to my CH341A(Black)? I used W25Q256JV with NeoProgrammer and on the chip is written Winbond 25Q256JVEN.
          On the DELL Latitude 5520 with XMC 25RH256CXIQ it worked totally well. Reading and writing. but not on W25Q256JVEN. But why
          • Thoa
            • Jun 2025
            • 28
            EDIT:
            I´m sorry. I think its a connection issue.
            • Thoa
              • Jun 2025
              • 28
              What about the 3.3V modification to the CH341A? I messured 3.28V on pin 4 to 8 without the modification. So what is that modification good for?
              When reading the WSON, I sometimes get some data, sometimes not, so i dont get 2 or 3 files which are identical.
              • peste
                • Dec 2016
                • 13377
                • ROMANIA
                #207
                The bios chip must be unsoldered from the board before writing or reading..
                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                solder wires between the programmer and the bios chip..
                here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                • Thoa
                  • Jun 2025
                  • 28
                  THX peste... You alread wrote that in 5520 bios unlock thread... I bought a pogo-pin tool, which worked great with my 5520. I do not understand, why mod the ch341a to 3.3 volt, when it is already 3.3volt without modification
                  • Thoa
                    • Jun 2025
                    • 28
                    Found it here:
                    https://www.youtube.com/watch?v=HwnzzF645hA
                    • Thoa
                      • Jun 2025
                      • 28
                      OK. I modified my CH341A to 3.3 V ... but still no reliable outcome. its so sad. I bought 3 pogo-pin tools. none is working. I think the problem is somewhere else. I tried AsProgrammer and NeoProgrammer. I ve tried W25q256FV and W25Q256JV.
                      • louie082588
                        • Aug 2022
                        • 11
                        • Philippine
                        #211
                        Good day everyone , can you please help me to remove admin password
                        Dell Latitude 5440
                        Model: model IDB40 LA M401P Rev 1.0 (A00) 2022-12-26
                        ST: JBM9D24
                        Thank You,
                        • LBTT1121
                          • Nov 2024
                          • 704
                          • Việt Nam
                          #212
                          Dell Latitude 5440
                          ST: JBM9D24
                          Thank You,
                          try
                            • 21641
                            Dell Latitude 5440
                            ST: JBM9D24
                            Thank You,
                            Depending on the suffix you might be able to unlock it yourself ,and others in future - https://www.badcaps.net/forum/troubl...23#post1622423
                            • Thoa
                              • Jun 2025
                              • 28
                              I bought a XGecu T48 now. But i cannot read the W25Q256FV@WSON8 :/
                              What am i doing wrong? I want to save this Latitude 5440 so bad...
                              APP Version : 12.96 Model : T48 MFG:2025-05-29
                              Device : W25Q256FV @WSON8
                              Pins Detected Passed!
                              Check ID Error!
                              Checked ID is:0x 00 00 00
                              Wish to continue programming , please cancel [Check device ID] option
                              • samueldourado
                                • Aug 2025
                                • 3
                                • Brasil
                                #215
                                Originally posted by Ubair Khan
                                Hello i dumped both bin files on respective chips and Laptop is completely dead - previously the power button led will turn on but nothing else - NOW nothing turns on when i press the power button the charging tiny LED turns on orange and thats it.
                                Kindly help with it Many thanks
                                Did you manage to solve it?
                                • samueldourado
                                  • Aug 2025
                                  • 3
                                  • Brasil
                                  #216
                                  Hello, could you help me remove the admin password from the bios?
                                  Dell Latitude 5440
                                  Modelo: modelo IDB40 LA M401P Rev 1.0 (A00) 2023-11-10
                                  ST: 1CTH244
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12262
                                    #217
                                    Dell Latitude 5440
                                    ST: 1CTH244
                                    Unlocked
                                    • Jm7016
                                      • Mar 2025
                                      • 9
                                      • Mexico
                                      #218
                                      Can you please help me unlock this Dell Latitud 5440 laptop BIOS?
                                      Dell Latitud 5440
                                      Numero de placa
                                      IDB40 LA M401P
                                      Rev 1.0
                                      Service tag 2L33X34
                                      • volinakis
                                        • Jan 2021
                                        • 2872
                                        • N/A
                                        #219
                                        Dell Latitud 5440
                                        Numero de placa
                                        IDB40 LA M401P
                                        Rev 1.0
                                        Service tag 2L33X34
                                        write only UC2, leave the other one as is.
                                        • xpy000
                                          • Feb 2022
                                          • 22
                                          • Morocco
                                          #220
                                          Hi guys,
                                          I have a dell latitude 5440 la-m402p with admin password
                                          service tag: 68ZL224
                                          The device has 64 mb chip not 32. The other bios chip is just 1 mb.
                                          I will be very grateful if you could help unlocking it.
                                            DELL Latitude 5440 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5440 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5440 boardview and 5440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5440...
                                            09-07-2024, 07:19 AM
