latitude 5440 la-m401p la-m402p password
  • osman68i
    • May 2015
    • 338
    • The Netherlands
    #121
    Originally posted by sancheti81
    please unlock bios password
    lattitude 5440
    st: C9RJY04
    mb code: la-m401p
    try
    • sancheti81
      • May 2014
      • 191
      • India
      #122
      Originally posted by osman68i
      try
      • sancheti81
        • May 2014
        • 191
        • India
        #123
        dell e5440
        service tag : CBY1C14
        8FC8
        • rex98
          • Feb 2023
          • 1268
          • Mandaue CEBU, Philippines
          #124
          dell e5440
          8FC8
          use this tool drag the 32mb to the patcher: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
          • its service
            • Feb 2021
            • 136
            • india
            #125
            Dell latitude 5440
            St : 9ndksv3-8fc8
            Problem : bios lock
              • 20665
              Originally posted by its service
              Dell latitude 5440
              St : 9ndksv3
              Problem : bios lock
              Read the post above yours....
              • ACHRAFJIRANI
                • Apr 2018
                • 65
                • MOROCCO
                #127
                dell latitude 5440
                st HGKMFY3
                PLS CLEAR ABSOLUT
                • its service
                  • Feb 2021
                  • 136
                  • india
                  #128
                  Sorry sir
                  • osman68i
                    • May 2015
                    • 338
                    • The Netherlands
                    #129
                    Sorry sir
                    try
                    • its service
                      • Feb 2021
                      • 136
                      • india
                      #130
                      try
                      Thanks laptop working fine
                      • Perovski
                        • Jul 2016
                        • 16
                        • Tunis
                        #131
                        Kindly asking for removal of locked bios password.
                        Latitude 5440, LA-M401P Rev:1.0(A00), Service Tag: 5KSJDY3​
                          SMDFlea commented
                          Editing a comment
                          Read the Bios Guides sticky thread, use the 8FC8 patcher, unlock it yourself
                      • markenero3
                        • May 2023
                        • 29
                        • Philippines
                        #132
                        Good day everyone pls need help i have dell lattitude 5440 laptop with locked bios with absolute enabled i already try the 8FC8 Patcher i successfully removed the bios lock but the absolute is still enabled pls can anyone help me for this thank you so much in advance <3
                        Here is my locked and absolute enabled bios
                        Service Tag: BCNYD14
                        • rex98
                          • Feb 2023
                          • 1268
                          #133
                          here
                          • markenero3
                            • May 2023
                            • 29
                            • Philippines
                            #134
                            Thank you so much sirrrrrr! It workssssssssss <3
                            • durianmustbeback
                              • Jan 2025
                              • 6
                              Hi pros here, I really need your help to start but just look like so dumb... My 5440 with LA-M401P has a chip 25R128JVSN. However I tried to run AsProgrammer1.4.1, CH341-main, and NeoProgrammerv2.2.0.10 but none of them have this chip. I then clicked "Read ID" or "Detect" try to find the chip but all just stuck there. I randomly chose an IC model and tried to read IC directly and the programmers are stuck too.
                              I then disconnected the cmos battery and chose W25Q256FV from AsProgrammer since its size is 33554432 which matches 25R128JVSN. I then clicked Read IC and surprising it can read in seconds. However it tells me "Number of bytes readed not equal IC size" error. I can save the reading to a 32MB sized file. But it only goes to ~20k when I compress it to zip file. Apparently it's not right since I see all the zipped bin files here are ~8MB.
                              ​Anything I did wrong or missed? How did you guys read this chip without support from the software? Your help is so appreciated!
                                • 20665
                                The W25Q256FV is 32MB , the 25R128JVSN is 16MB
                                • durianmustbeback
                                  • Jan 2025
                                  • 6
                                  Thank you! But what chip should I use instead since 25R128JVSN is not listed in AsProgrammer?
                                    SMDFlea commented
                                    Editing a comment
                                    Winbond 25Q128JV
                                • durianmustbeback
                                  • Jan 2025
                                  • 6
                                  I can read now but can only read all 0. Saved and compressed to zip it's only 20kb. What did I do wrong? Thank you
                                  • volinakis
                                    • Jan 2021
                                    • 2709
                                    • N/A
                                    #139
                                    are you using clamps? It's not reliable, especially with CH341, desolder chipset and read it using SOIC_DIP adapter or solder it on the board came with Ch341
                                    • durianmustbeback
                                      • Jan 2025
                                      • 6
                                      I see. Will desolder it and try. Thanks a lot!
                                        DELL Latitude 5440 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5440 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5440 boardview and 5440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5440...
                                        09-07-2024, 07:19 AM
