Removing DELL G5 5590 TPM device is not detected error.
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    The southern chip has changed. It displays late. and at startup it gives the error TPM device is not detected.
    Can we cleanme and remove the error message?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: Removing DELL G5 5590 TPM device is not detected error.
    Sevice tag number ?
    • ay_bulut
      • Feb 2016
      • 114
      • turkey
      Originally posted by hoaca388
      sevice tag number ?
      8k3khs2
      • ktmmotocross
        Dell Vostro 5590 onboard memory error - how to disable/repair it?
        by ktmmotocross
        Hello. Have this Dell Vostro 5590 K4AAG165WB-MCTD that show 2x orange+5 white led blink which is memory error. i try to search in schematic but there are no option for no onbooard memory.
        I try to edit bios by SPD removal tool 1.6 but non options work for me and laptop dont even normally start like without ram
        so how to repair this error?
        02-04-2025, 09:04 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • Healdealer
        Dell G5 15 5590 - No ram detected ( 2,3 )
        by Healdealer
        It looks like i did a mistake when changing some settings for the ram with setup_var_3 commands in grub.
        First it worked all for unlock undervolting, but then i changed the frequency or i used a wrong var value..
        Now no boot and no screen.
        Led code 2 amber 3 white no ram detected.
        I installed 2 different new ram but no luck.
        RTC reset not helping
        Cmos reset not helping
        I tried everything what the manual say and what i could find elswhere.
        Is there a possibiliTy to revert my mistake ?
        Why is...
        08-20-2024, 06:34 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
