acer sp314-21 bios need
  • lashamafia
    • Nov 2017
    • 22
    • georgia
    Hello need bios for acer SP314-21 motherboard Lenny_Dal 203014-1M
    • 22009
    Re: acer sp314-21 bios need
    You MUST:
    • mferna14
      • Jun 2018
      • 1046
      Dear Friend., can someone fix the BIOS for ACER Spin 314-21N. The laptop turns on fine. Works well but after 2 or 3 days it just does not turn on. LDO 3.2V is good on the ON/OFF Swtich. Then I have to remove the battery terminal & way you go, back in action. I will start with a clean BIN file, maybe some problems with the bin file. Kindly someone could redo with a clean BIOS file. Thanks in advance
      ACER SP314-21N-R6X6
      Serial # NXA4EAA001104025D16600
      Motherboard Lenny_Dal 203014-1M​
      • mferna14
        • Jun 2018
        • 1046
        ACER SP314-21N-R6X6
        Dear friends., it's more than 48 hr no one has helped me. If some one can kindly re-built this ACER bin file, I would appreciate. Thanks for the help
        • hoaca388
          Badcaps
          • Jan 2022
          • 12354
          Model Number: SP314-21N
          Serial Number : NXA4EAA001104025D16600
          • mferna14
            • Jun 2018
            • 1046
            @hoaca388 , thanks buddy you really come to the rescue., I programmed & till now the laptop is working fine. Let's see. Thanks once again
            • EbrahimSiami
              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
              by EbrahimSiami
              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
              **What I have tried so far:**
              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
              07-02-2025, 02:31 PM
            • Wg188
              ACER Veriton Z4660G AIO bios help
              by Wg188
              I have an Acer veriton Z4660G all in one pc,
              Model: Z4660G-I5850H1 (VZ4660G_W)
              Need bios dump and schematic would save my life !
              to make a long story short I bought this all in one used
              with a broken lcd, with the objective of making a custom desktop out of it
              ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
              06-17-2023, 02:20 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • James194zt
              Acer Nitro 50-640E Corrupted BIOS Dump
              by James194zt
              My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
              All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
              04-28-2025, 03:29 PM
            • ub6ib969
              Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
              by ub6ib969
              Model Number: PO3-650
              Part Number: DG.BK4AA.006
              Serial Number : 33400117730
              BIOS IC : XM25QH256C
              I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
              07-02-2025, 03:51 PM
