Lenovo Legion Y740-17IRHg Bios Corrupted Need Help
  • asusasus
    • Jul 2023
    • 13
    Hello everyone , my Lenovo Legion Y740-17lRHg Bios Corrupted Need Help
    Model Name : 81UJ
    Serial Number: MP1M554T
  • hoaca388
    Badcaps
    • Jan 2022
    • 11878
    Re: Lenovo Legion Y740-17lRHg Bios Corrupted Need Help
    Model Name : 81UJ
    Here
    • asusasus
      • Jul 2023
      • 13
      Originally posted by hoaca388
      Here
      Thanks but still not working
      • hoaca388
        Badcaps
        • Jan 2022
        • 11878
        My file posted is the original file from Lenovo, you should look for another reason.
        • alfredposadas09
          • Aug 2020
          • 343
          • Philippines
          100% working bios if this not work then u have problem in hardware
          • asusasus
            • Jul 2023
            • 13
            Re: Lenovo Legion Y740-17IRHg Bios Corrupted Need Help
            Thank you guys , I think is the hardware issue
            • Loki_Fido
              • Mar 2025
              • 110
              • Japan
              Hi bud,
              Did you end up figuring out what the issue was?
              Do let us know please
              • Loki_Fido
                • Mar 2025
                • 110
                • Japan
                Originally posted by Loki_Fido
                Hi bud,
                Update, I found a shorted GDDR5, after removing it i found the GPU was shorted with 0 ohms.
                Usually, there will be integrated GPU with the processor. But in this laptop there wasn't. Therefore when the laptop was started, it just spins the fan and lots of lightworks only.
                Had to be used for parts.
                • Kyo_Kun2345
                  Acolyte
                  • Aug 2025
                  • 6
                  Lenovo Legion Y740-17IRHg (Type: 81UJ, MB: LA-G132P, CPU: i7-9750H, GPU: RTX 2070), a failure occurred during a Bios update and the screen wouldn't turn on, but keyboard would light up. Backed up Bios bin file (see attachment) and attempted to flash the Bios chip (CH341A SPI Programmer with SOIC8 Test Clip, Software: Flashrom on Linux), using what I thought was a good Bios bin file. After a 'successful' flash the keyboard doesn't even light up now, even after I re-flashed back to the old Bios. Hoping to get a Bios file to attempt a flash.
                  • peste
                    peste commented
                    Editing a comment
                    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                • peste
                  • Dec 2016
                  • 12941
                  • ROMANIA
                  post S/N...
                  • Kyo_Kun2345
                    Acolyte
                    • Aug 2025
                    • 6
                    Originally posted by peste
                    post S/N...
                    S/N: mp1ltwab
                    Thanks for linking this, I'll be sure to search better in the future. I tested the Bios.bin file provided and it doesn't work. I assume that means this is hardware related?
                      • 21145
                      S/N: mp1ltwab
                      try
                      • Kyo_Kun2345
                        Acolyte
                        • Aug 2025
                        • 6
                        @SMDFlea that worked, thanks so much!
                        • Kyo_Kun2345
                          Acolyte
                          • Aug 2025
                          • 6
                          Well, it did work, now after a few reboots the keyboard lights up, but not the display (external display also gets no signal) so I clearly have a hardware issue in addition to the Bios one... thanks for your help again!!!
                          Update: Yep, definitely a hardware issue. I was able to get it to boot up, then while in the Bios screen went black and it shut down. I'll post again if I figure it out!
                          • grimacelord
                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                            by grimacelord
                            Hello there.
                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                            History:
                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                            I searched for this error online and discovered...
                            03-15-2023, 03:29 PM
                          • TylerHyde21
                            Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                            by TylerHyde21
                            Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                            I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                            I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                            This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                            06-29-2024, 10:38 AM
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                            LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                            This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                            09-12-2024, 02:30 PM
