good evening you can help me I have an HP ELITEBOOK x360 1030 g7 fpm30 la-j442p rev 0.3. When I received the PC it did not turn on so I flashed the BIOS with the 1040 G7 dump so it turns on now but no display I need the BIOS trash to origin. Here is my old dump.
HP EliteBook x360 1030 g7 LA-J442P
Re: HP x360 1030 g7 LA-J442P
HP EliteBook x360 1030 G7 Notebook PCAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donate -
(Reposting as requested)
Have a system with a broken SSD connector. Got a replacement motherboard from China. Upon install it was slow to start and had 5 slow flashes of caps lock. Resetting to defaults resulted in not being able to get back to BIOS screens, requiring a reflash of the chip (image provided by board supplier). Same result.
I installed EC and BIOS from a donor board, then updated BIOS via network. System was working (did not brick after loading defaults) but still had slow start. Identified ME as likely culprit in slow boot and 5 flash symptom.
First, I double checked CSME tools versions to make sure they matched ME version (14.1.70.2228). I loaded the donor bios file into Intel FIT and changed Intel ME Binary File parameter to point to the ME RGN file (14.1.70.2228_COR_LP_BA_PRD_EXTR-Y_7EB3AD1F as there is not proper image in the 14.1 repository) and built a new image. I then burned that outimage.bin file back. 5 flashes is gone, but so is the SSD disk - it is suddenly no longer recognized. I've done all resets and it will not show up. Also went through the process again (in case I missed something) with the same result. I don't see where what I did is really any different than the process outlined in the ME Firmware Cleaning Guide, except for the Create Intermediate Files option. So, not sure what happened here. Any possibility of recovery?
I'd like to know what I did wrong here, rather than just upload files and have someone fix it. I can of course upload any files required for analysis.
Appreciate any assistance. Assuming I can get this resolved, I will still be left with a 'HP Endpoint Security Controller Problem', but one thing at a time. (I think this is because SN doesnt match.) Thanks in advance.
SN of donor is CND1139BMR
SN of replacement is CND11939PT
System board is FPM30 LA-J442P
('Donor' files are dumps from old broken system board - had broken SSD connector
'New' files are dumps from EC chip from replacement board and BIOS as provided by China guys.)
SSSS(Reposting as requested)
'New' files are dumps from EC chip from replacement board and BIOS as provided by China guys.)Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
That seems to have done the trick, thank you. Would you mind outlining the steps taken, so that I may learn from this experience? What I did wrong, what things I omitted? In any case thanks very much for that assistance.Comment
I just followed the instructions here : https://www.badcaps.net/forum/troubl...22#post1622422↵
Hi, Can you please clean DMI information (s/n and others) so I can use this bios on a second HP X360 1030 G7? Or have you got just a clean bios, so I can add DMI info later on?
I tried a BIOS from HP website (matching "S93") sp151282.exe for HP EliteBook x360 1030 G7 Notebook PC, but it didn't work (won't turn on). I might be doing something wrong.Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hello all, I have a HP EliteBook 1030 G7 that has had a failed bios update
and I just have a blank screen and the fan is on full speed, could be other problems.
I am uploading the original files there is no password on this bios.
Can a pro please have a look and try to fix.
Serial number, CMD05151W2
Motherboard model, FPM30 LA-J442P Rev 1.0
I did try a few sets I found online but I am getting Endpoint Security Error.
Thanks.Attached Filesif you find these attachements useful please consider making a small donation to the site
tryHello all, I have a HP EliteBook 1030 G7 that has had a failed bios update
Can you please enable the MPM mode in the attached BIOS? I was trying many times to do so via HP BIOS Configuration Utility, but I always end up with Error Code 6 (Access Denied).
HP Elitebook x360 1030 G7. Motherboard FPM30 LA-J442P, Rev.1.0. S/N: CND1023N04. System bios "S93".Attached Filesif you find these attachements useful please consider making a small donation to the site
here u go.Hi,
use BCU to fill these DMI info:
Serial Number: CND1023N04
Product #/SKU: 2K9F8EC#ABU
CT Number: PKLVNG51WEP6WA
Description: HP EliteBook x360 1030 G7 No
BuildID: 20WWHCBT601#SABU#DABU
Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVbhcAdUdpdqfPguhKhWhZjhk8mE.mEAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank you rex98. Your MPM-enabled BIOS works fine.
here u go.
Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVbhcAdUdpdqfPguhKhWhZjhk8mE.mEComment
Hi guys,
Have a x360 1030 g7 here, that apparently suffered a BIOS update. Came back to life after ejecting the battery but now it has this annyoing "endpoint security controller" bug (will HP ever fix this? as I have had plenty from customers with this annoying message).
s/n: CND0452Q57
What file do you require? The 16 or 32MB file?Comment
32MBHi guys,
s/n: CND0452Q57
What file do you require? The 16 or 32MB file?↵
Off topic, this thread is for the 1030 G7. Post your request in the 11 G7 EE thread -> https://www.badcaps.net/forum/troubl...ebook-11-g7-eeComment
here u go.
OKK BIOS
This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 08:27 AM
This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 06:40 AM
This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 05:33 AM
This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-06-2024, 11:32 AM
- Loading...
