HP EliteBook x360 1030 g7 LA-J442P
  • Alassane
    • Oct 2018
    • 65
    • MALI
    good evening you can help me I have an HP ELITEBOOK x360 1030 g7 fpm30 la-j442p rev 0.3. When I received the PC it did not turn on so I flashed the BIOS with the 1040 G7 dump so it turns on now but no display I need the BIOS trash to origin. Here is my old dump.
    Last edited by Vesko356; 01-16-2024, 05:50 PM. Reason: Added "EliteBook" to thread title
  • hoaca388
    Badcaps
    • Jan 2022
    • 11865
    Re: HP x360 1030 g7 LA-J442P
    HP EliteBook x360 1030 G7 Notebook PC
    • Alassane
      • Oct 2018
      • 65
      • MALI
      thank you for this bin.But i tried it does not turn on.It only show caps lock light
      • oscarmeyer
        • Apr 2019
        • 12
        • Uruguay
        (Reposting as requested)
        Have a system with a broken SSD connector. Got a replacement motherboard from China. Upon install it was slow to start and had 5 slow flashes of caps lock. Resetting to defaults resulted in not being able to get back to BIOS screens, requiring a reflash of the chip (image provided by board supplier). Same result.
        I installed EC and BIOS from a donor board, then updated BIOS via network. System was working (did not brick after loading defaults) but still had slow start. Identified ME as likely culprit in slow boot and 5 flash symptom.
        First, I double checked CSME tools versions to make sure they matched ME version (14.1.70.2228). I loaded the donor bios file into Intel FIT and changed Intel ME Binary File parameter to point to the ME RGN file (14.1.70.2228_COR_LP_BA_PRD_EXTR-Y_7EB3AD1F as there is not proper image in the 14.1 repository) and built a new image. I then burned that outimage.bin file back. 5 flashes is gone, but so is the SSD disk - it is suddenly no longer recognized. I've done all resets and it will not show up. Also went through the process again (in case I missed something) with the same result. I don't see where what I did is really any different than the process outlined in the ME Firmware Cleaning Guide, except for the Create Intermediate Files option. So, not sure what happened here. Any possibility of recovery?
        I'd like to know what I did wrong here, rather than just upload files and have someone fix it. I can of course upload any files required for analysis.
        Appreciate any assistance. Assuming I can get this resolved, I will still be left with a 'HP Endpoint Security Controller Problem', but one thing at a time. (I think this is because SN doesnt match.) Thanks in advance.
        SN of donor is CND1139BMR
        SN of replacement is CND11939PT
        ​System board is FPM30 LA-J442P
        ('Donor' files are dumps from old broken system board - had broken SSD connector
        'New' files are dumps from EC chip from replacement board and BIOS as provided by China guys.)
        • hoaca388
          Badcaps
          • Jan 2022
          • 11865
          SSSS
          • oscarmeyer
            • Apr 2019
            • 12
            • Uruguay
            That seems to have done the trick, thank you. Would you mind outlining the steps taken, so that I may learn from this experience? What I did wrong, what things I omitted? In any case thanks very much for that assistance.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11865
              I just followed the instructions here : https://www.badcaps.net/forum/troubl...22#post1622422
              • Kazik
                • Oct 2016
                • 53
                Hi, Can you please clean DMI information (s/n and others) so I can use this bios on a second HP X360 1030 G7? Or have you got just a clean bios, so I can add DMI info later on?
                I tried a BIOS from HP website (matching "S93") sp151282.exe for HP EliteBook x360 1030 G7 Notebook PC, but it didn't work (won't turn on). I might be doing something wrong.
              • Dan20701
                • Sep 2020
                • 199
                Hello all, I have a HP EliteBook 1030 G7 that has had a failed bios update
                and I just have a blank screen and the fan is on full speed, could be other problems.
                I am uploading the original files there is no password on this bios.
                Can a pro please have a look and try to fix.
                Serial number, CMD05151W2
                Motherboard model, FPM30 LA-J442P Rev 1.0
                I did try a few sets I found online but I am getting Endpoint Security Error.
                Thanks.​
                • danito
                  • Jun 2016
                  • 981
                  Thanks.​
                  try
                  • Dan20701
                    • Sep 2020
                    • 199
                    Thank mate, will give this a go soon.
                    • Kazik
                      • Oct 2016
                      • 53
                      Can you please enable the MPM mode in the attached BIOS? I was trying many times to do so via HP BIOS Configuration Utility, but I always end up with Error Code 6 (Access Denied).
                      HP Elitebook x360 1030 G7. Motherboard FPM30 LA-J442P, Rev.1.0. S/N: CND1023N04. System bios "S93".
                      • rex98
                        • Feb 2023
                        • 1281
                        • Mandaue CEBU, Philippines
                        here u go.
                        use BCU to fill these DMI info:
                        Serial Number: CND1023N04
                        Product #/SKU: 2K9F8EC#ABU
                        CT Number: PKLVNG51WEP6WA
                        Description: HP EliteBook x360 1030 G7 No
                        BuildID: 20WWHCBT601#SABU#DABU
                        Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVbhcAdUdpdqfPguhKhWhZjhk8mE.mE​
                        • Kazik
                          • Oct 2016
                          • 53
                          Originally posted by rex98
                          here u go.
                          Thank you rex98. Your MPM-enabled BIOS works fine.
                          • dutchgaucho
                            • 60
                            • The Netherlands
                            Hi guys,
                            Have a x360 1030 g7 here, that apparently suffered a BIOS update. Came back to life after ejecting the battery but now it has this annyoing "endpoint security controller" bug (will HP ever fix this? as I have had plenty from customers with this annoying message).
                            s/n: CND0452Q57
                            What file do you require? The 16 or 32MB file?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11865
                              Originally posted by dutchgaucho
                              Hi guys,
                              s/n: CND0452Q57
                              32MB
                              • qwerty4512
                                • Dec 2024
                                • 29
                                • US
                                PLEASE HELP ME UNLOCK THIS TYPE HP PROBOOK X360 11 G7 EE
                                S/N : 5CG1191N28
                                THANKS FOR YOU HELP
                                  • 21117
                                  S/N : 5CG1191N28
                                  THANKS FOR YOU HELP
                                  Off topic, this thread is for the 1030 G7. Post your request in the 11 G7 EE thread -> https://www.badcaps.net/forum/troubl...ebook-11-g7-ee
                                    HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 08:27 AM
                                    HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 06:40 AM
                                    09-06-2024, 05:33 AM
                                    HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-06-2024, 11:32 AM
