HP 14-cf0002nj bios
  • koby058
    • Jan 2017
    • 394
    • israel
    HP 14-cf0002nj bios
    Hi
    Fail to load after windows update
    can you please help with bios?
    attached old
    thanks people
    • 22283
    Re: HP 14-cf0002nj bios
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • koby058
      • Jan 2017
      • 394
      • israel
      OK
      model: 14-cf0002nj
      prodID: 4PQ49EA#ABT
      s/n: 5CG9061F88
      if MOBO model is critical please tell me since i must disassemble it
        • 22283
        No.No need to disassemble it.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          OK
          model: 14-cf0002nj
          prodID: 4PQ49EA#ABT
          s/n: 5CG9061F88
          [Guide] How to extract ready for programming dump from HP update executable file
          https://www.badcaps.net/forum/showthread.php?t=121948
          https://www.badcaps.net/forum/showth...54#post1261154
          Originally posted by SMDFlea
          When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
          220000 - 221FFF
          Become a Badcaps supporter
          Thanks to all supporters.​
          • koby058
            • Jan 2017
            • 394
            • israel
            Worked Thanks
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Worked
              Great! Good for you.
              You're welcome.
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
