HP 14-cf0002nj bios
  • koby058
    • Jan 2017
    • 374
    • israel
    HP 14-cf0002nj bios
    Hi
    Fail to load after windows update
    can you please help with bios?
    attached old
    thanks people
    • 20743
    Re: HP 14-cf0002nj bios
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • koby058
      • Jan 2017
      • 374
      • israel
      OK
      model: 14-cf0002nj
      prodID: 4PQ49EA#ABT
      s/n: 5CG9061F88
      if MOBO model is critical please tell me since i must disassemble it
        • 20743
        No.No need to disassemble it.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          OK
          model: 14-cf0002nj
          prodID: 4PQ49EA#ABT
          s/n: 5CG9061F88
          [Guide] How to extract ready for programming dump from HP update executable file
          https://www.badcaps.net/forum/showthread.php?t=121948
          https://www.badcaps.net/forum/showth...54#post1261154
          Originally posted by SMDFlea
          When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
          220000 - 221FFF
          Become a Badcaps supporter
          Thanks to all supporters.​
          • koby058
            • Jan 2017
            • 374
            • israel
            Worked Thanks
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Worked
              Great! Good for you.
              You're welcome.
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • Julian Bailey
                BIOS update wont complete - Dell Latitude 7420
                by Julian Bailey
                Hi all
                Anyone come across this issue where a BIOS flash will only part complete?
                It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                The drive works fine in another laptop.
                Link to a video I made of what its doing here:
                Any ideas on how to overcome this?
                Cheers...
                06-02-2025, 01:39 PM
