help ec kb9012 bios dell 5547 LA-B012P thanx's
This topic is closed.
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: help ec kb9012 bios dell 5547 LA-B012P thanx's
    Your request doesn't meet the rules.
    Missing:
    Full model name
    Service tag
    Original (EC) dump
    Issue description
    In addition there's existing thread for this laptop and you should post in it, instead of creating a new topic.
    Thread closed.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jeewantha
      DELL Inspiron 15-5547 BIOS
      by jeewantha
      I want to clean this bios for DELLInspiron 15-5547
      Model : DELLInspiron 15-5547
      Motherboard : ZAVCO LA-B012P
      : Rev : 1.0:
      Serial No : C7MY702
      Thank you very much to whoever can help me with this....
      12-21-2024, 08:27 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
