Hp elitebook 840 g9
  • rex98
    • Feb 2023
    • 1293
    • Mandaue CEBU, Philippines
    #121
    Originally posted by maobuff
    Can someone unlock bios for HP elitebook 840 g9?
    SN# 5CG23634TL
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    here's your DMI:
    Serial Number: 5CG23634TL
    Product #/SKU: 6Z4A9UP#ABA
    CT Number: PQSPN00WBH31K5
    Description: HP EliteBook 840 14 inch G9
    BuildID: 22WWWPAT602#SABA#DABA
    Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEmwn7nVngpDpVpqqjqz.Eg
    MAC Address : 38:CA:84:4E:F9:E1​
    • maobuff
      • Jul 2024
      • 5
      • Ukraine
      #122
      here's your DMI:
      Hi. First boot f10 and I'm able to reset to factory defaults. on second boot I'm unable to enter bios. It always freeze on entering setup and restart after few seconds. Bios is still locked.
      • rex98
        • Feb 2023
        • 1293
        #123
        try again
        • maobuff
          • Jul 2024
          • 5
          • Ukraine
          #124
          try again
          Same, after restoring factory defaults next boot always fails.
          • danito
            • Jun 2016
            • 1097
            • Romania
            #125
            Try
            1. Flash Patched File
            2. in First BOOT got to SETUP in MAIN Tab Restore Factory Defaults
            3. Save and Exit
            4. Flash back Original Bios BIN File
            • maobuff
              • Jul 2024
              • 5
              • Ukraine
              #126
              Originally posted by danito
              Try
              3. Save and Exit
              Can I just solder wires to bios chip to save time? ofc I will remove bios battery and main battery.
              • danito
                • Jun 2016
                • 1097
                • Romania
                #127
                I don't know, yes, remove the batteries.
                • maobuff
                  • Jul 2024
                  • 5
                  • Ukraine
                  #128
                  Try
                  3. Save and Exit
                  What I did:
                  1)desoldered bios chip
                  2)flashed bios with verification
                  3)put laptop together(connecting everything)
                  4) after connecting bios battery and main battery laptop turned on with f5 and f8 light up and fanspin, then it powered off, then again f5 and f8 light.
                  5) on second reboot backlight turned on and Im able to enter bios, in main tab I selected reset to manufactures default and exit
                  6) laptop turned on with f5 and f8 lights, after 1-2min turned off
                  7) removed motherboard and desoldered bios chip
                  8) flashed my original dump and soldered it back
                  9) assembled laptop and again after pluging main battery it turned on with f5 and f8 lights
                  10) after 2 reboots again screen backlight turned on and i was able to enter bios(f10) and its still locked
                  I have assumption that f5 and f8 it is some sort of memory training because its an ddr5.
                  • Mrnixdorf
                    • Sep 2016
                    • 130
                    • Morocco
                    #129
                    Please remove BIOS Administrator Password
                    hp Elitebook 840 G9​
                    6050A3417601 MB A01
                    SN 5CG30614P3
                    • rex98
                      • Feb 2023
                      • 1293
                      #130
                      hp Elitebook 840 G9
                      6050A3417601 MB A01
                      SN 5CG30614P3
                      here's your DMI:
                      Serial Number: 5CG30614P3
                      Product #/SKU: 6B4Y0AV
                      CT Number: PQSPP00WBHO2JN
                      BuildID: 22WWWPAD301#SABD#DABD
                      Feature Byte: 3Y6E6J6S6a7H7M7R7W7d7j7m7saEawbUbhcAfAfPguhKhkjhk8m6n7nVngpFpTqjqz.2e​
                      • Mrnixdorf
                        • Sep 2016
                        • 130
                        • Morocco
                        #131
                        [QUOTE=rex98;n3317671]
                        here's your DMI:
                        lot of thanks worked 100%
                        • iampachi
                          • Oct 2022
                          • 10
                          • México
                          #132
                          Por favor elimine la contraseña de administrador del BIOS
                          hp Elitebook 840 G9
                          6050A3417601 MB A01
                          SN 5CG3027M3C
                          Archivos adjuntos
                          • rex98
                            • Feb 2023
                            • 1293
                            #133
                            hp Elitebook 840 G9
                            6050A3417601 MB A01
                            SN 5CG3027M3C
                            Archivos adjuntos
                            here's your DMI:
                            Serial Number: 5CG3027M3C
                            Product #/SKU: 6W029UP#ABA
                            CT Number: PQSPQ00WBHLER9
                            BuildID: 22WWWPBZ601#SABA#DABA
                            Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPgSguhKjhk8mEn7nVngpFpVpnpqprqjqz.dy
                            MAC Address : 7C:4D:8F:37:61:FD​
                            • iampachi
                              • Oct 2022
                              • 10
                              • México
                              #134
                              here's your DMI:
                              worked 100% thanks
                              • serginio
                                • May 2018
                                • 16
                                • UKR
                                #135
                                Hello! Can you help me to unlock bios?
                                Model: 840 G9
                                SN: 5CG3133N35
                                • serginio
                                  • May 2018
                                  • 16
                                  • UKR
                                  #136
                                  Model: 840 G9
                                  SN: 5CG3133N35
                                  Can someone help me?
                                  • farouk_1994
                                    • Mar 2021
                                    • 399
                                    • algeria
                                    #137
                                    Serial Number: 5CG3133N35
                                    try this than replay
                                    • serginio
                                      • May 2018
                                      • 16
                                      • UKR
                                      #138
                                      Your bios the same as a locked
                                      • rex98
                                        • Feb 2023
                                        • 1293
                                        #139
                                        try
                                        use BCU. you can permanently disable Absolute lock in BCU.​
                                        • Mrnixdorf
                                          • Sep 2016
                                          • 130
                                          • Morocco
                                          #140
                                          Model: ELITEBOOK 860 G9
                                          SN 5CG3063R73​
                                          Off topic.Don`t hijack threads when the model number is different. You have already asked for the bios once https://www.badcaps.net/forum/troubl...g9#post3331962
