bios for hp PROBOOK 455 G9
  • rex98
    • Feb 2023
    • 1297
    • Mandaue CEBU, Philippines
    #41
    I noticed there's a lot of unlock request for this model HP ProBook 455 G9
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    frequently asked questions:
    can i use this to my HP ProBook 455 G9- yes
    This is the both BID U78 and U88 its all you need.
    This bios main is from official website then added VSSTORE and patched so its fast-boot just like intel clearme.
    to determine your BID use hex editor and search U88 or U78 in your main bios bin, you know the rest.
    • moshu
      • Oct 2024
      • 66
      • Ireand
      #42
      Thanks rex98. I confirm it is working fine.
      Took me almost half a day to to write the chips because is not easy to me to unsolder them from MB and put them back without damaging plastic around them.
      What would be the bios version that will require patching only main chip?
      also to put original DMI I was using BCU but I was not sure if I could use the original one to write the settings or only some settings? What do you recommend?
      • rex98
        • Feb 2023
        • 1297
        #43
        your's is U78
        and this is your DMI
        Serial Number: 5CD2315F08
        Product #/SKU: 4S0R3AV
        CT Number: PPQNF048JGY00W
        Description: HP ProBook 455 15.6 inch G9
        BuildID: 22WWTPBT602#SABU#DABU
        Feature Byte: 476J6S6b7B7J7M7Q7W7saBapaqauawbhcAdpdqfPguk8mEn7nWpFpqqjqz.qf
        MAC Address : 5C:60:BA:B8:62:3C
        • moshu
          • Oct 2024
          • 66
          • Ireand
          #44
          your's is U78
          thanks, I have those information as well, except MAC address.
          If the bios version is not new (08/11/2022), can I only patch the main chip?
          • rex98
            • Feb 2023
            • 1297
            #45
            just follow my instructions flash both. if you want latest bios just update
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              #46
              use Kapton tape for plastic parts around bios chipsets. Since March 2024 HP changed security and models with bios newer than March 2024 can't be patched to enter mpm. Rex98 files are very good to unlock HPs, update bios in steps - use a version from 2023, then other from 2024 and so on. Personally I use files where they updated ME versions, I had a update failure when I tried to update directly to last version. MAC Adress is on a label on motherboard, as well as CT.
              • moshu
                • Oct 2024
                • 66
                • Ireand
                #47
                I've flash the main chip, hopping I will not have to flash the SPI chip (is not easy for me to attach wires or removed from motherboard) and now laptop doesn't boot. There were several attempts to start (looking on the power LED) but nothing on the screen.
                Then I've flash both chips but still nothing is happening.
                When I plug in the power cable, CapsLock LED and power LED (key) does light 4 seconds, then power LED (key) turn off and NumKey LED + LED from charging port, light for ~2 seconds then nothing else is happening.
                With or without DDR same behavior.
                Any way I can make it boot again?
                • volinakis
                  • Jan 2021
                  • 2877
                  • N/A
                  #48
                  dude, flash BOTH chipsets as rex98 said, don't try to reinvent warm water!
                  • moshu
                    • Oct 2024
                    • 66
                    • Ireand
                    #49
                    Eventually I did and Laptop doesnt boot
                    • volinakis
                      • Jan 2021
                      • 2877
                      • N/A
                      #50
                      yep, you wrote 1st main then power up laptop, didn't work so you wrote EC without writing again main, right? You tried to reinvent the wheel this time...
                      Rex explained to you that you have to write BOTH IN SAME TIME, then power up laptop. You are the kind that you find a problem for every solution ...
                        • 22279
                        What programmer are you using, did you erase the chips before programming
                        • moshu
                          • Oct 2024
                          • 66
                          • Ireand
                          #52
                          I've used T48 (I am looking to buy a Vertyanov Successor Programmer or a svod4 programmer but dont know which one to pick and where to buy from ; I will appreciate if you can help here too).
                          With T48 before programming, there is an erase step which took ~100seconds.
                          On this laptop, I've programed the main chip without removing the chip from motherboard and connected the CMOS battery otherwise an error in the verify stage would appear.
                          One think I will try is to remove the main chip on the motherboard and try try again.
                          First laptop I program both chips (main removed from motherboard and the SPI programmed using wires on motherboard; I am not so skilled with hot-gun as of now) and did worked eventually.
                          If there is a way to fix the current issue on this laptop which is not booting, please let me know
                          • One stop shop
                            • Dec 2021
                            • 3
                            • Nigeria
                            #53
                            Please can someone help me out with the images of the two bios chips and the surrounding resistors.I was trying to desolder the bios chip and accidentally knocked one or two components off and I'm trying to identify them.It doesn't post anymore,just 7 blinks.Any help will be appreciated,thanks
                            • moshu
                              • Oct 2024
                              • 66
                              • Ireand
                              #54
                              here are some pictures.
                              Good Luck
                              • One stop shop
                                • Dec 2021
                                • 3
                                • Nigeria
                                #55
                                Good Luck
                                Thanks alot, I see a resistor in the wrong position,I'll fix that and post an update
                                • moshu
                                  • Oct 2024
                                  • 66
                                  • Ireand
                                  #56
                                  Is there any way to program the EC without pulling out from motherboard?
                                  I am able to read it using T48 but I am not able to erase it properly.
                                  SVOD4 is not able to recognize it show " status register 1 0XFF " & "status register 2 0XFF "
                                  CH 341 is not able to provide enough current so does disconnect the programmer once I connect the wires.
                                  • karemkf
                                    • May 2020
                                    • 22
                                    • egypt
                                    #57
                                    hi ineed unloke file
                                    sn-2tk22507rr
                                    mb da0x9smb8d1 rev
                                      • 22279
                                      sn-2tk22507rr
                                      mb da0x9smb8d1 rev
                                      Off topic, this thread is for the 455 G9. Your serial number is for the 645 14 inch G9
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • Godfather79
                                        Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                        by Godfather79
                                        Hello everyone in the community
                                        Dear Sir,
                                        I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                        Problem details:
                                        * Model: Dell Latitude 5520.
                                        * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                        * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                        * Service Tag: (Enter your actual Service Tag from the laptop here)
                                        * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                        11-08-2025, 10:04 AM
                                      • Godfather79
                                        by Godfather79
                                        Dear Sir,
                                        I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
                                        Problem details:
                                        * Service Tag: (HMHJQ93)
                                        What I need:
                                        Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
                                        In the attachment...
                                        Today, 07:18 PM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • Soumana Sanou
                                        “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                        by Soumana Sanou
                                        Hello,😇😇😇
                                        I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                        🔧 Model: HP ProBook 11 G2
                                        📦 Serial Number: 8CG72478MY
                                        🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                        🔒 BIOS Status: Locked with password
                                        The laptop is no longer under warranty and HP refused to help me.
                                        I’m looking for a custom SMC.bin file.
                                        I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                        Thanks a lot for your help!🙏🙏🙏...
                                        06-17-2025, 04:04 PM
