T431s bios dump
  • pumpkinpie132
    • Jun 2023
    • 6
    T431s bios dump
    Pls this is for the Lenovo thinkpad t431s!
    Last edited by pumpkinpie132; 07-03-2023, 02:26 PM. Reason: Forgot to add what company the laptop is
    • 22279
    Re: T431s bios dump
    Provide a BIOS/EC dump if possible
    Attach files directly to your post instead of linking to external websites
    • pumpkinpie132
      • Jun 2023
      • 6
      Re: T431s bios dump
      Srry I meant if anyone has one?
        • 22279
        Re: T431s bios dump
        Also post the laptop serial number and a description of the issue, no boot,black screen, no boot after windows update etc..
        • pumpkinpie132
          • Jun 2023
          • 6
          Re: T431s bios dump
          I need to find the cfg lock parameter to use the cfg unlock. I am hackintoshing this laptop
          • pumpkinpie132
            • Jun 2023
            • 6
            Re: T431s bios dump
            I do not have access to a chip clip to dump my bios there is nothing wrong with the bios. But I need a dump of it to insert into uefitool to find the cfg lock. I have already searched the forums and I have not found a bios dump for this laptop yes I need a bios backup
            • pumpkinpie132
              • Jun 2023
              • 6
              Re: T431s bios dump
              If anyone had one
              • Gbolahan John o
                • 27
                • Nigeria
                LENOVO T431s lock, please help unlock
                LST-1 MB 48.4YQ02.021 12235-2
                TYPE 20AC-A04800
                S/N R9-001H7K 13/10
                PLEASE UNLOCK
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Joluvillas
                  Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                  by Joluvillas
                  Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                  06-18-2024, 10:35 PM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
