Lenovo IdeaPad 3 15ARE05 strange BIOS behavior
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    it came with no display, power button blinking all the time. I did read bios and saw it has some strange bytes in Padding area, I thought is a bios bug so I wrote a new bios extracted from lenovo site. All was ok, after few days laptop came back with same symptoms, i did read again bios and noticed Padding area having again strange bytes. Maybe someone can help me understand why this is happening, what can cause this strange thing.thank you.
  • Haker5
    Banned
    • Mar 2015
    • 65
    • internet
    Re: Lenovo IdeaPad 3 15ARE05 strange BIOS behavior
    try and raport
    • volinakis
      • Jan 2021
      • 2877
      • N/A
      Originally posted by Haker5
      try and raport
      thank you but I have a working bios, the problem is that for sure if I will write again after few days will do the same thing, I want to understand why is happening that strange thing.
      • hardware1
        • Sep 2021
        • 2951
        • N/A
        It's not a strange bytes, if you mean the data between (0-3000h) it's the DMI of this Lenovo Laptop, it will be empty in the Virgin BIOS so you will need to move it from the Original dump to the New one to keep the DMI save.
        all donations are welcome,
          • 22293
          The code before that LDBG is probably Debug code ? ,not sure.
          Edit: LCFC debug
          • hardware1
            • Sep 2021
            • 2951
            • N/A
            I really don't know what this code is, but I think it's used to arrange the DMI, because I can see it mentioned many times between the encrypted DMI.
            I always copy the data from "LDBG" to the end of the DMI (no matter what length it was, 2000h, 3000h or 4000h) and it's always working fine.
            I'm also wondering about the Windows Key because I can't see it in plain text for these Lenovo devices.
            • volinakis
              • Jan 2021
              • 2877
              • N/A
              I think DMI is between 1000-2FFF - usually i search for "LENV" to find DMI data.
              • mkdj
                Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                by mkdj
                Dear all,
                I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                Here the steps I have taken to fix the laptop:
                - downloaded latest BIOS from Lenovo Website...
                10-18-2025, 03:43 AM
              • jendkkd jeje
                Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                by jendkkd jeje
                So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                10-11-2024, 03:12 PM
              • joven016
                Lenovo Ideapad S145 need working bios HELP!!
                by joven016
                Problem is blinking power led only
                i don't know exactly if it's s145-15igm or s145-14igm
                have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                Already tested some of posted bios here
                S145-14igm - success but invalid serial and not booting on OS
                S145-15igm - success with serial and some other info in bios but still not booting on OS
                already tried installing new windows but always booting on bios setup
                windows installer flash drive detected on...
                08-21-2025, 10:55 PM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • mximiliandz
                help bios lenovo ideapad s145-14iil type 81w6
                by mximiliandz
                Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                06-20-2025, 06:50 AM
