LG Gram 17Z990 (EAX68255702 Rev 1.3) BIOS needed
  • evgenymgv
    • Sep 2014
    • 21
    • Russian Federation
    Hello, dear forum users. I really need a dump for LG Gram 17Z990. The BIOS flash drive is out of order, it cannot be read by the programmer.
    Thank you very much in advance!!!
  • evgenymgv
    • Sep 2014
    • 21
    Re: LG Gram 17Z990 (EAX68255702 Rev 1.3) BIOS needed
    Can someone help me please! I really need a bios dump...
      • 22114
      What model is your programmer and software version,is the chip in the support list.Are you using a clip or has the chip been desoldered.
      • evgenymgv
        • Sep 2014
        • 21
        Desoldered. Programmers i try: TL866 ll Plus, RT809H, CH341
        Chip in support list (25q12872)
        • evgenymgv
          • Sep 2014
          • 21
          Still up to date...
            • 22114
            Still up to date...
            Can`t find any 17Z990 dumps or virgin bios.The 15Z990 might share the same bios,ive seen a dump on some paid sites.
            • evgenymgv
              • Sep 2014
              • 21
              Thanks for the info. However, due to certain circumstances, I, unfortunately, do not have the opportunity to purchase firmware on foreign resources. In addition, I have not seen this firmware anywhere (I mean 15Z990).
              • Maxim Skridonenko
                • Apr 2018
                • 17
                • Украина
                tested working
                • VOvoshch
                  • Jan 2023
                  • Ukrain
                  Originally posted by maxim skridonenko
                  tested working
                  Спасибо большое! Thanks a lot!
                  • evgenymgv
                    • Sep 2014
                    • 21
                    Originally posted by Maxim Skridonenko
                    tested working
                    Thank you very much! Большое Вам спасибо!
                      • 22114
                      tested working
                      Thanks for sharing
                      • Olimpiu Puscas
                        Olimpiu
                        • Jan 2024
                        • 13
                        • Ireland
                        tested working
                        I will try it later, thank you so much !!
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • vinaypundith
                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                          by vinaypundith
                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                          08-03-2024, 12:32 PM
                        • hotcrossedbuns999
                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                          by hotcrossedbuns999
                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                          3. I could only locate two chips that look like bios chips. Could someone verify this
                          01-03-2025, 12:32 PM
                        • James Maxwell
                          HP DM1-4000er Bios Dump needed
                          by James Maxwell
                          I badly need bios dump for HP DM1-4000er,
                          Model: HP DM1-4000er
                          Motherboard: DA0NM9MB6D0 REV.D
                          Product: QJ490EA#ACB
                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                          10-28-2024, 05:38 PM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
