req bios hp14s -fq0022au
  • sito
    • Apr 2016
    • 24
    • indonesia
    help me please
    Laptop nodisplay problem hp14s -fq0022au model 0PAE
    DA0PAEMB6D0
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: req bios hp14s -fq0022au
    Originally posted by sito
    help me please
    DA0PAEMB6D0
    https://www.badcaps.net/forum/showpo...00&postcount=2
    Become a Badcaps supporter
    Thanks to all supporters.​
    • sito
      • Apr 2016
      • 24
      • indonesia
      thanks, I'll try it
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
      • legendkray
        BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
        by legendkray
        I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
        07-05-2025, 09:25 AM
      • Loli Popu
        DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 03:28 AM
      • bschwand
        ASUS N550JK laptop reboots after 30 minute, BIOS extracted invalid...
        by bschwand
        as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
        I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
        Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...
        05-22-2024, 02:48 AM
