need help to modify a bios dumped from set-top box
  • jason0503
    • Dec 2018
    • 27
    The set-top box has a TV silicon tuner IC MXL608, which has a programmable channel selection filter (6MHz/7MHz/8MHz), and the default value is 8MHZ, but the manufacturer sets the set-top box to 6MHZ. How can I change this value by modifying the dumped bios? I tried using UEFITool.exe, but it doesn't work. The BIOS of the TV box is different from that of the computer. I don't know how to modify it or what tool to use. I downloaded the data sheet of MXL608, which mentioned that when the value of SYMBOL is set to 2.85, BW=6MHZ. When the value of SYMBOL is 3.75, BW=8MHZ, but I can't find the corresponding place after opening the BIN file with HDX. Please help me, thank you
    mxl608 IC datasheet
    dumped bios
  • Diah
    • Feb 2013
    • 6445
    first of all need to know the system installed on the box , open source or closed one....
    BTW what are the brand of the box... by advanced setting and manual scan i think you can set the Freq you are wishing to receive
    • jason0503
      • Dec 2018
      • 27
      Thanks for your reply. The brand of this set-top box is gelect. Sorry I am not sure what operating system it is, but there is no information about the Android version in the system information. In addition, it should not be open source. There is no option to change the bandwidth in the system settings. I have searched and there is no such option. When searching for signals, the default setting is 6MHZ and cannot be changed. This is a system composed chips of MSD7831 8880 60X chips.
      • Diah
        • Feb 2013
        • 6445
        Originally posted by jason0503
        but there is no information about the Android version in the system information. .
        you are talking on Android... android are open source... only the DVBAPI some brands close it to avoid open paid channel ..
        please post system Info screen shoot.. and the setting menu from it could know which android ita is..
        if you can dump the boot section.. will be helpful , or if you can root it so you can have to hidden file xml related to DVB program there can be changed too.
        i put here apk if you can install it by sideloaded ADB or direct with usb
        • lotas
          • Jan 2016
          • 4761
          • Russia
          Well, what kind of android is there with a MSD7831 cpu, rather an ordinary digital set-top box for TV and dump there on a regular spi flash 25Q32 (64). Why does Android need a TV tuner?
          • Diah
            • Feb 2013
            • 6445
            i think he did mistake.. Android never installed on spi or eeprom.. it only on SSD / eMMC / NAND. , tuner on android its good things i do have 2 set box android 7.1.2 with tuners.. one with T2/C/SAT, the other only SAT. so i can watch all scramble channel via SAT and C via OSCAM.
            • jason0503
              • Dec 2018
              • 27
              i can boot into uboot now and get some message ,any ideas ?
              u32TunerFreq = -1 u8BandWidth = -1
              1 3 1
              Tuner locked
              MxL608_0x5B : 10
              MxL608_0x5C : b1
              MxL608_0xC2 : a9
              1 3 0​
              console out .txt
              • Diah
                • Feb 2013
                • 6445
                yours UNIX MSTAR. its open and the firmware key easly to find for extraction and recompile change, try find firmware for yours box and use MSTAR tool to do the change for Demode List.
                • jason0503
                  • Dec 2018
                  • 27
                  MSTAR tool unpacking error occurred 'UnicodeDecodeError: 'utf-8' codec can't decode byte 0xbf in position 4097'. This set-top box does not have a FLASH storage chip. Does the MSD7831 have an integrated FLASH hard disk? I uploaded the firmware
                  gelect__31-05-16v26-upgrade.rar
                  • jason0503
                    • Dec 2018
                    • 27
                    This model has no NAND on the motherboard, I confirm
                    • Diah
                      • Feb 2013
                      • 6445
                      its look closed at module
                      " line 42, in <module>
                      offset = header.find('\xff'.encode(encoding='iso-8859-1'))
                      UnicodeDecodeError: 'ascii' codec can't decode byte 0xff in position 0: ordinal not in range(128)"
                      try on linux machine.. my i don't have right now under hand.
                      • jason0503
                        • Dec 2018
                        • 27
                        Many people have encountered similar problems
                        https://github.com/dipcore/mstar-bin-tool/issues/20
                        • jason0503
                          • Dec 2018
                          • 27
                          Add three lines at the beginning of unpack.py ( python versions below 3.0):
                          import sys
                          reload(sys)
                          sys.setdefaultencoding('iso-8859-1')
                          but is nothing useful out ,a header and header_script out in unpacked folder ,no Demode List?
                          [i] Analizing header ...
                          [i] Saving header script to unpacked\~header_script ...
                          [i] Parsing script ...
                          [i] Parsing setenv usb_complete -> 1
                          [i] Parsing setenv usb_upgrade -> 0
                          [i] Parsing setenv bootcmd -> ' spi_rdc 0x80b00000 0xa001c 0x2b6d8b; LzmaDec 0x80b00000 0x2b6d8b 0x80000180 0x81000000; go 0x80000224;
                          [i] Done.​
                          • Diah
                            • Feb 2013
                            • 6445
                            MSTAR tool had limited , but when you work on Linux machine, "binwalk" can do more effective
                            • jason0503
                              • Dec 2018
                              • 27
                              I used binwalk to extract the files(here), but it didn't seem to work.
                              • thslr2020
                                [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
                                by thslr2020
                                Hello.
                                I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
                                1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
                                2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
                                3. Disabled Intel ME, Hyper-V & Vt-d
                                4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
                                5. Try from fresh Win 8.1(boot with USB)
                                Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but...
                                06-14-2023, 12:09 AM
                              • Kentsfield
                                Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
                                by Kentsfield
                                I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
                                Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
                                I desoldered the flash IC MX25U12872F and dumped the flash.
                                I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
                                08-04-2025, 07:46 AM
                              • caspian
                                How can I modify An EC firmware?
                                by caspian
                                Dear members,
                                I have an HP Elitebook 2540P laptop with mainboard: LA-5251P REV 1.0
                                It has a SIO with model: SMSC KBC1098
                                I think both the EC firmware and the main Bios reside in a single Bios chip.
                                Problem: KBC1098 is partially defective so that it does not generate ADP_En at Pin 75 and generates 8 amber blinks on the charging LED, indicating some wrong input.
                                Idea: Now I need to modify the EC firmware so that KBC1098 ignores the wrong input conditions and always generates a high ADP_En and does not enter a failure state.
                                Is it possible...
                                05-21-2024, 01:35 PM
                              • hexdy
                                Modify BIOS to non-uefi
                                by hexdy
                                Hello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
                                05-14-2024, 10:31 AM
                              • yooolaaa
                                DELL 5420 LA-K491P Please help me modify
                                by yooolaaa
                                Customer demand, can anyone help me change the model text in this bios to 5430, it was originally displayed as 5420, I tried searching the text in winhex to modify it but it didn't work, it didn't work or it didn't display
                                05-20-2024, 08:15 PM
