Asus X705NC Bios Request
  • joby91
    • Sep 2018
    • 40
    • german
    can someone help me to fix this bios.
    My Laptop is Asus Vivobook 17 with mainboard X705NC.
    All voltages are present and the laptops is turning on after 10-15 tries. When the laptop is on it is staying on.
    I have tried to clean the ME Region myself but i was unable.
    Hope someone can help me.
    In attachement is the Original Bios.
    Thanks in advance.
  • peste
    • 12941
    • ROMANIA
    Re: Asus X705NC Bios Request
    Thanks in advance.
    bios extracted from the Asus website update..
    • joby91
      • Sep 2018
      • 40
      • german
      it is not working. I have tried the same yesterday from the Asus website and was not working. I have tried again with your bios and the same.
      When the laptop is working cpu core has 0.94v and when the laptop ist turning on with black screen cpu has 0.84v.
      I have tried yesterday with another bios, and the cpu voltage was 0.94 but i had black screen. The bios was from another asus laptop x705uv and mine is x705nc.
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        hello,
        it is not working. I have tried the same yesterday from the asus website and was not working. I have tried again with your bios and the same.
        once more
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • skurvysyn
          BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
          by skurvysyn
          laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
          original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
          01-08-2025, 04:45 PM
