help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
  • trunguntilyou
    • Aug 2022
    • 349
    • Vietnam
    #121
    Originally posted by hoaca388
    Try
    bios ok ,,, but a bit slow :v
    • Chak83
      • Jun 2025
      • 3
      • DE
      #122
      I have a HP ZBook Fury 15 G8 with BIOS admin password.
      Can someone please unlock it?
      ProdID: 5S1R1EC#ABD
      Serial: CND2244LHL
      BIN file is attached.
      Thank you.​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12032
        #123
        ProdID: 5S1R1EC#ABD
        Serial: CND2244LHL
        Thank you.​
        Post EC file.
        • Chak83
          • Jun 2025
          • 3
          • DE
          #124
          Can someone tell me where I can find the EC file or where the chip is located for reading it? Thank you very much.
          Is the attached file perhaps the correct one?
          • rex98
            • Feb 2023
            • 1287
            • Mandaue CEBU, Philippines
            #125
            since you don't know where the ec is use this alternative.
            first boot press f10 apply factory defaults and restart, 2nd boot press f10 goto security settings reset security settings to defaults.
            after that flash back your original bios main or just input manually the DMI i provided in BCU
            Serial Number: CND2244LHL
            Product #/SKU: 5S1R1EC#ABD
            CT Number: PMWMEH3MYGTMH8
            Description: HP ZBook Fury 15.6 inch G8 M
            BuildID: 21WWAVBT601#SABD#DABD
            Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBapaqauawb8bhdpdqfPhkk8mEmwn7nPnVngpDpq.AN​
            • Chak83
              • Jun 2025
              • 3
              • DE
              #126
              Hey,
              thank you very much!
              • politomi
                • Nov 2024
                • Magyarország
                #127
                I have a HP ZBook Fury 15 G8 with BIOS administartor password.
                Serial: CND30125DK
                Thank You!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12032
                  #128
                  Serial: CND30125DK
                  Thank You!
                  HP ZBook Fury 15.6 inch G8 Mobile Workstation PC
                  Serial_CND30125DK
                  Product_31Z44AV
                  CT Number_6LGXF0HWYHA23Y
                  Build Id_21WWAVBT601#SABD#DABD
                  Fearture byte_476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbhcAdpdqfPhkk8mEmSn7nPnVngpDpq.72
                  • politomi
                    • Nov 2024
                    • Magyarország
                    #129
                    Serial_CND30125DK
                    Product_31Z44AV
                    It works! Thank you very much!
                    Let me to give you a big virtual hug!
                    • ktvdung89@gmail.com
                      • Sep 2022
                      • 17
                      • viet nam
                      #130
                      Endpoint Security Controller Problem and not detect ssd PCIe, please help, thanks ALL!
                      SN : CND1318JKD
                        • 21389
                        SN : CND1318JKD
                        Try the endpoint patcher script - https://www.badcaps.net/forum/troubl...security-error
                          • Sep 2022
                          • 17
                          • viet nam
                          #132
                          Originally posted by SMDFlea
                          Thanks, Looks like VSS2 doesn't fix not detected PCIe ssd error, can you help me with SSD problem
                            • Sep 2022
                            • 17
                            • viet nam
                            #133
                            worked thank you
                            • bejaoui
                              • Feb 2017
                              • 56
                              • ariana
                              #134
                              Hp Zbook Fury 17.3 inc G8 With admin password
                              SN# : CND1483NFZ
                              PROD ID :547P8EC#ABD
                              please unlock this bios password ​
                              • bejaoui
                                • Feb 2017
                                • 56
                                • ariana
                                #135
                                SN# : CND1483NFZ
                                please help me
                                • trunguntilyou
                                  • Aug 2022
                                  • 349
                                  • Vietnam
                                  #136
                                  please help me
                                  Try
                                  • bejaoui
                                    • Feb 2017
                                    • 56
                                    • ariana
                                    #137
                                    Originally posted by trunguntilyou
                                    Try
                                    Caps Lock LED blinking 7 times
                                    • bejaoui
                                      • Feb 2017
                                      • 56
                                      • ariana
                                      #138
                                      please help me solve the problem
                                      I tried with the dumps that I have saved the same problem
                                      • trunguntilyou
                                        • Aug 2022
                                        • 349
                                        • Vietnam
                                        #139
                                        i only partially repaired your original bios ,,, in theory it is no different from the original bios ,, your laptop should still boot ,,, so what did you do wrong before ,,, now repairing the bios cannot solve your problem
                                        • tcbucher
                                          BIOS Locked on Zbook Fury 17 G7 J203P Motherboard
                                          by tcbucher
                                          Been working to unlock a zBook Fury G7 17, SER# 2TK1380178.
                                          Has a removable MacronixMX25L256 BIOS chip. Have attempted to unlock the BIOS with multiple suggestions using a CH341A programmer.
                                          Any help unlocking the bios password would be appreciated. Bios attached.
                                          Thanks...
                                          12-13-2024, 11:34 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • reeza_plus
                                          HP ZBOOK FURY 16 G11 BIOS UNLOCK
                                          by reeza_plus
                                          MODEL: HP ZBOOK FURY 16 G11
                                          Hi please help unlock this bios
                                          SN: 5CG44640QC...
                                          03-19-2025, 05:12 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                          HP ZBook Fury 16 G10 Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Fury 16 G10 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 G10 boardview and 16 G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                          09-07-2024, 07:20 AM
