Lenovo Yoga 11e(4th gen) bios
  • OKRPKCOMP
    • Dec 2020
    • 439
    • PAKISTAN
    YOGA 11e
    Board Code: DALI8GMB6D0 REV D
    Plz clean this bios, Backup attached
  • akcworld.2009@gmail.com
    • Feb 2020
    • 6
    • INDIA
    Re: Need Yoga 11e Clean Bios
    What issue
      • Feb 2020
      • 6
      • INDIA
      Originally posted by okrpkcomp
      yoga 11e
      board code: Dali8gmb6d0 rev d
      plz clean this bios, backup attached
      thanks
      your clean txe version 3 file
      with rsa sign key
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        Thanks sir, its working fine
        Fault was late display and auto shutdown after 5 mints and sometime no post
        how u did this, will u share pls
        • motanya
          • Nov 2021
          • 162
          • Kenya
          I need Lenovo yoga 11e bios bin file This laptop is from another repair shop the bios on board is not even being detected, is totally damaged, 100% confirmed so I do NOT have the original BACKUP, the below information is all that I can get,
          motherboard: DALI8KMB8D0 REV D
          Type: 20HS
          Can't find the serial number so if you are able to work with the above information and give me a working bin I will be highly grateful
          • hani55
            • 104
            • morocco
            Re: Lenovo Yoga 11e(4th gen) bios
            https://www.badcaps.net/forum/showthread.php?t=92907
            • motanya
              • Nov 2021
              • 162
              • Kenya
              Thank you but the link is for lenovo e145 do they share the bios?
              • hani55
                • 104
                • morocco
                Same motherboard with you just have to experiment
                • motanya
                  • Nov 2021
                  • 162
                  • Kenya
                  Unfortunately, it does not work, also the motherboard number is not the same. This one is DALI8 the other is DALI2
                  • peste
                    • Dec 2016
                    • 13721
                    • ROMANIA
                    Type: 20HS
                    did you try this???
                    https://www.badcaps.net/forum/showth...ht=DALI8KMB8D0
                    • motanya
                      • Nov 2021
                      • 162
                      • Kenya
                      Thanks peste. With this the fan spins at full speed with no display, one question the broken bios chip that was onboard is mxic25l12873g I have used Winbound 25q128fv, is that okay?
                      • peste
                        • Dec 2016
                        • 13721
                        • ROMANIA
                        try..
                        • snaks
                          • Feb 2014
                          • 6
                          • Bulgaria
                          Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                          Hello, can you help me with password protected bios? I try it with autopatcher, but it doesn't generate me patched file (i didn't find generated file).
                          Lenovo Yoga 11e
                          TYPE 20HS-S08F00
                          S/N LR-09GRKY 17/07
                          • snaks
                            snaks commented
                            Editing a comment
                            Can you help me,please????
                          • snaks
                            snaks commented
                            Editing a comment
                            I fix it with older version of python.
                        • nabilgo
                          • May 2016
                          • 304
                          • L.A
                          HI CAN ANYONE DO CLEAN ME REGION FOR THIS BIOS IT TAKE SO LONG TO START
                          LAPTOP MODEL LENOVO YOGA 11E
                          BORAD NUMBER DALI8KMB8D0 REV D
                          SERIAL NUMBER SL10M89582
                        • danito
                          • Jun 2016
                          • 1141
                          • Romania
                          try
                          • testinglaptops
                            • Oct 2022
                            • 85
                            • United Arab Emirates
                            with rsa sign key
                            Thanks 100% working for me, I tried on 2 laptops, working on both
                            • Nadeem Amin
                              • 33
                              • pakistan
                              I use a bios bin from here.after flashing bios mainboard hv no power.3v and 5v and 1v also present.powwr button hv volt and battery connector hv data clk 3.3v also.after pressing reset botton power supply show 0.045 load.before flash a bios ,there is no display issue.thwn reflash old backup file same condition,no power.then I noticed this mainboard is hv ci5 7th gen CPU DDR4 RAM.any suggestions please,
                            • Nadeem Amin
                              • 33
                              • pakistan
                              This
                                SMDFlea commented
                                Editing a comment
                                type and post the laptop serial number.....
                            • Nadeem Amin
                              • 33
                              • pakistan
                              Type,--20HS-S00Q00. S/N LR-09JF0W 17/07
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12403
                                Yoga 11e 4th Gen Laptop (ThinkPad) - Type 20HS
                                • to5it0
                                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                  by to5it0
                                  Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                  I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                  This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                  I have opened the laptop and identified the main BIOS chip...
                                  10-24-2025, 01:35 AM
                                • maeson
                                  BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
                                  by maeson
                                  Hi dear Badcaps-Community,
                                  Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
                                  I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
                                  The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
                                  Lenovo Yoga L13 Gen 3 AMD:
                                  Lenovo Modell: Type 21BB
                                  Artikelnr.21BB006GGE
                                  Seriennummer: PW0A6207
                                  AMD Ryzen™ 5 PRO 5675U
                                  Memory 16 GB DDR4-3200MHz
                                  SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
                                  10-31-2025, 03:08 AM
                                • DiddiAb
                                  BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                                  by DiddiAb
                                  Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                                  I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                                  03-11-2023, 03:15 AM
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • beogeek
                                  Lenovo Yoga Slim 7 14APU8 Bios Request
                                  by beogeek
                                  I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                                  Attached is the bios dump in the state I received it...
                                  10-24-2024, 12:54 PM
