i already remove the bios password when i conect to internet it pop up message and cannot use the laptop
HP 840 G8 Bios Unlock
Serial Number: 5CG3021T01
Product #/SKU : 509H3UC#UUF
CT Number: PQSMT00WBHL4HK
Description: HP EliteBook 840 G8 Notebook
BuildID: 21WWCVET601#SUUF#DUUF
Attached FilesComment
Hi guys,
I have a 840 g8 which was stuck in boot loop, I flashed both main and ec bios with the bios from one of the posts on this thread (it's t39 version) but now it shows even less life - only caps lock light turns on. I would ask for a clean main and ec bios, I can add DMI later. Much obliged.
HP Elitebook 840 G8
SN: 5CG2117DR9
hi can someone help me endpoint security error HP G8 840 i7 11th generation
Model: HP EliteBook 840 G8
S/N: 5CG1461WNJ
Board: 6050A3426501-MB-A02
MAINAttached FilesComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
post S/N, full name and model, motherboard model,.product number,etc.
Every donation made will go towards server fees and maintenance costs.Comment
Hello my dear friend! Can you help me unlock the BIOS laptop?
S/N: 5CG23618P6
Board-Model: 6050A3419601-MB-A01
ProdID: 4J5R7EC#ABD
Chip-model: Winbond 25Q256JVEN | 2220 - 6206 - 21900Attached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by spmetroilHello,
I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
I have a CH341A programmer and I already attempted the following steps:- Identified the correct chip (W25Q128, 3.3V SPI flash).
- Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
- Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
08-19-2025, 09:23 AM - Loading...
