Please can someone help me remove the password - HP 840 g8 - serial number 5CG208CCQD - MBoard - CORVETTE-6050A3217501-MB-A01(A1)
HP 840 G8 Bios Unlock
CT Number_6LEPT10TZG2BB1
Serial_5CG208CCQD
Sku_48R31EA#ABU
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPguhKhkjhk8mEmGmwn7nVngpD.NA
Build Id_21WWCVCT602#SABU#DABUAttached Files↵
https://www.badcaps.net/donateComment
Please can someone help me to remove the bios password;
Hp EliteBook 840 G8
Serial: 5CG208CB9T
Motherboard: CORVETTE-6050A3217501-MB-A01(A1)
Thanks in advanceAttached FilesComment
CT Number_6LEPT10TZG29CQ
Serial_5CG208CB9T
Sku_48R31EA#ABU
Hello, can you help me disable the administrator and absolute passwords?
S/N : 5CG3022WCWComment
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CG3022WCW
Product #/SKU: 4Q1N2LS#ABM
CT Number: PQSMV00WBHL3KI
Description: HP EliteBook 840 G8 Notebook
BuildID: 21WWCVET601#SABM#DABM
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPguhKhkjhk8mEn7nVngpDpq.B3
MAC Address : 7C:4D:8F:33:2F:5EComment
I am having trouble soldering the chip back, it either gets blown off-position a bit by my hot air gun or it seems to not be completely level once the solder sets.
Any tips? possibly a drip of glue to keep it in place?Comment
do not touch the ec.
here's your DMI:
please clear this bios 6050a3419601-mb-a01 (1086) L2
Serial Number : 5CG147DFKJ
Product Number : 515V5UC
Description : HP EliteBook 840 G8
FEATUREBYTE 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfPgSguhKjhk8mEmwnVngpD.3FAttached FilesComment
Hi , Please help to unlcok bios for :
HP Elitebook 830 G8
SN 5CG211B1DD [MOD EDIT] its an 840 G8
Thank youAttached FilesComment
HP EliteBook 840 G8 Notebook PC
CT Number_6LGWR0JXXG18BW
Serial_5CG211B1DD
Sku_45Y11EC#ABM
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
Build Id_21WWCVET601#SABM#DABMAttached Files↵
I think I made things worse. Now the only light that is (always) on is fn and the power button doesn't do anything. Guess I'll unsolder and re-verify the chip still is okay.Comment
Off topic , this thread is for the 840 G8, your previous off-topic post was moved to the 830 G8 thread topic --> https://www.badcaps.net/forum/troubl...e5#post3495599Comment
can anybody help me unlocking ADMIN password on my dump
serial number: 5CG23037K3Attached FilesComment
Attached Files↵
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by spmetroilHello,
I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
I have a CH341A programmer and I already attempted the following steps:- Identified the correct chip (W25Q128, 3.3V SPI flash).
- Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
- Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
08-19-2025, 09:23 AM - Loading...
