HP 840 G8 Bios Unlock
    Originally posted by João Almeida View Post
    actualized
    Your file gives me wrong output
    If possible try reading the MAIN BIOS again
      actualized
      first boot press f10 apply factory defaults and exit. use BCU.
      Serial Number: 5CG3061WYQ
      Product Number: 4E0Q1EC#ACH
      CT Number: PQSMT00WBHP29C
      Description: HP EliteBook 840 G8 Notebook
      BuildID: 21WWCVET601#SACH#DACH
      Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPguhKhkjhk8mEmVn7nVngpDpq.h2
      MAC Address : 7C:4D:8F:3F:85:02
        Please unlock...swat lock
        Serial Number: 5CG22817KG
        Product Number: 509H3UC#UUF
        BuildID: 21WWCVET601#SUUF#DUUF
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
          do not touch the EC.
          First boot apply factory defaults and exit, 2nd boot reset security settings to defaults and exit.
          Use BCU fill these DMI info:
          CT Number: PQSNT00WBGUJ08
          MAC Address : 5C:60:BA:C8:08:E4
            Please unlock...
            Serial Number: 5CG1480DDG
            Product Number: 4U4B8US#ABA
              Originally posted by trunguntilyou View Post
              Please unlock...
              Send to you, first boot press f10 apply factory defaults and exit. use BCU.
                It worked, thank you very much, I just learned how to crack passwords using EC files, I wonder if passwords can be broken using one of two files, it's true that the more I learn, the more stupid I feel :v
                  how to remove passwords using ec chip? please share so we can learn as well.
                  Thank you
                    Thank you
                    Here i made that.
                      Originally posted by rex98 View Post
                      Here:
                      very understandable! Thanks! Just do the same and you will succeed
                        After i unlock password on my laptop HP Elitebook 840 G8 i find this problem : HP endpoint security controller problem tool
                        Serial Number: 5CG1247GD4
                        Product Number: 358N6EA#UUW
                        please help
                          please help
                          CCC
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            Originally posted by hoaca388 View Post
                            CCC
                            Think you its working but with alert : system is booting in manifacturing Program Mode...
                              Once in Windows, download BCU utility and run the executable file to generate a configuration file. Modify the file to make manufacturing mode to go away by changing asterisk from "*Unlocked" to "*Locked" and watch for any errors.
                                Hello.
                                Can you clear my BIOS password?
                                Model: HP EliteBook 840 G8
                                S/N: 5CG211CBF2
                                Board-Model: 6050A3426501-MB-A02
                                ProdID: 4Y9T4EC#ABB
                                Chip-model: Winbond 25Q256JVEN
                                I have two bios dump files.
                                Top of board and bottom of board
                                  Originally posted by Deeloc View Post
                                  Hello.
                                  S/N: 5CG211CBF2
                                  ProdID: 4Y9T4EC#ABB
                                  first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                  use BCU. you can permanently disable Absolute lock in BCU.
                                  here's your DMI:
                                  Serial Number: 5CG211CBF2
                                  Product #/SKU: 4Y9T4EC#ABB
                                  CT Number: PQSNL00WBGEWDB
                                  BuildID: 21WWCVET601#SABB#DABB
                                  Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfPguhKhkj4jhk8mEmwn7nVngpDpq.MB
                                  MAC Address : 3C:18:A0:C8:8B:7B
                                    here's your DMI:
                                    Works.
                                    Big thanks
                                      Please I would like to clean the Bios password!
                                      SN_5CG1501WR2
                                        SN_5CG1501WR2
                                        here's your DMI:
                                        Serial Number: 5CG1501WR2
                                        Product #/SKU: 26D60AV
                                        CT Number: PKUHC00WBG111S
                                        BuildID: 21WWCVCT602#SABD#DABD
                                        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVngpD.Bh
                                        MAC Address : C0:18:03:2D:A1:07
                                          SN_5CG1501WR2
                                          Hi everyone, I flashed the patched file but it gives me the error lights on the keyboard and it doesn't turn on! I checked the checksum and everything is the same as the file you gave me..
