HP Pavilion 15t-eg100 - corrupt bios
  • brock-s
    • 48
    Hello, I'm working on an HP Pavilion 15t-eg100, part number 43F48AV. Upon attempting to power-on, the caps lock blinks twice and it shuts off. HP indicates this blink code means corrupt bios. (The owner stated it worked when they last shut it down, but failed to boot next time they went to use it.)
    I've attempted the BIOS recovery steps published by HP (e.g. ctrl-v, ctrl-b, ctrl-esc) without success. (Including creating a BIOS recovery usb flash drive).
    Attached is a dump of the contents of the GigaDevice 25B127DSIG chip (dumped using TL866A programmer, using settings for Winbond W25Q128BV).
    The motherboard is a DA0G7HMB8H0 Rev H. (HP part number M74949-601)
    The latest bios for this laptop is available from HP at: https://ftp.hp.com/pub/softpaq/sp143...0/sp143436.exe (I think it's the 0898A.bin file).
    I've searched these forums but could not find a thread for an HP with this chip with a corrupted bios.
    I'm hoping someone take the DMI info from the dump and incorporate it into the latest bin file from HP please?
  • peste
    • Dec 2016
    • 13395
    • ROMANIA
    Re: HP Pavilion 15t-eg100 - corrupt bios
    bios extracted from HP website update
    DMI+KEYWIN 500000 - 50103F
    • hardware1
      • Sep 2021
      • 2946
      • N/A
      Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
      Serial Number: 5CD20989P6.
      all donations are welcome,
      • brock-s
        • 48
        Thank you both for the prompt responses. Sorry for the late reply, I've been away from the bench for much of the day. I tried both files provided (they had different SHA hashes, so I thought if one didn't work maybe the other would). Neither worked. The laptop attempts to POST 4 times (i.e. the power light comes on, then off for 5 seconds, then on for 5 seconds, then off for 5 seconds, etc) and on the 4th time when the power light comes on - this is when the caps lock blinks twice and everything turns off and stays off.
        • peste
          • Dec 2016
          • 13395
          • ROMANIA
          the laptop probably has another problem or you write it with errors..
          • brock-s
            • 48
            Just a quick follow-up: Resistance of cpu supply inductors to ground is 0 to 0.1ohms. Inspected all MLCC's for cracks under microscope - no problems found. Injected 0.8volts at coils, eventually current maxes out at 1.6amps at 0.8volts. Viewed top and bottom of board with thermo-camera - no hot or warm spots found. Suspect internal layer shorted (which may have enough thermal mass to not heat up enough to be detectable).
            I don't think there's much more that can be done at this point to repair this (at least not cost effectively).
            I'd like to thank peste and hardware1 for their fast responses!
            I've made a donation to the forum as this place is such a valuable resource for me. And, on those occasions, when advice I've asked for (or found through searching) has fixed the problem - it has saved me a motherboard or an entire laptop. To anyone reading this, a donation to this site is MUCH better than having to replace a motherboard or laptop!
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Very well and truly said.
              The more people follow you, the better for community here.
              Thanks for supporting the forum once again!
              Become a Badcaps supporter
              Thanks to all supporters.
              • Bloodhoundje
                HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                by Bloodhoundje
                I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                I have desoldered the bios chip (GigaDevice...
                03-16-2024, 03:12 PM
              • TripTop
                Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                by TripTop
                Hi
                i have dell latitude E7270 with following symptoms:
                - takes long time to restart.
                - sometimes powers on and then off
                - sometimes while working it just dies,
                From googling online bios clean could possible resolve this?
                i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                I reinstall...
                09-09-2024, 02:05 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • sssssssssssssss
                Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                by sssssssssssssss
                I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                Symptoms:
                • Laptop powers on but no display at all (completely black screen)
                • Caps Lock blinks twice with a pause, then repeats continuously
                • F12 LED stays on permanently
                • No POST, no boot sequence, nothing on screen
                Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                What I've tried:
                • Hardware reset (battery removal, power
                09-04-2025, 06:45 AM
              • grimacelord
                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                by grimacelord
                Hello there.
                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                History:
                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                I searched for this error online and discovered...
                03-15-2023, 03:29 PM
