Lenovo T480 no boot , only melody .
  • Bizb9l21
    • Jan 2023
    • 26
    • Usa
    Purchased a T480 Lenovo from eBay .
    The laptop won't boot just play melody and keyboard light come on and then the laptop turns off.
    Disconnected everything, HDD, LCD connector, and the other long connection on the top , removed bios battery, tested we good working ram from my T470.
    Same result, no signs of water damage, won't display anything on HDMI .
    Used the Lenovo app the code comes up is : 0285
    TCG-compliant functionality-related error (might be the TPM initialization failure)
    When I try to scan the serial number it makes beeps but the app is unable to recognize it.
    Any ideas ?
  • Bizb9l21
    • Jan 2023
    • 26
    • Usa
    Re: Lenovo T480 no boot , only melody .
    I saw in a few places that flashing a fresh bios with clean ME would help, i do have a EZP2019 programer that I used for flashing apple MacBook BIOS chips but I understand that the T480 has 2 chips, would I need to flash both of them?
    I saw somewhere that I can download the bios from Lenovo:
    https://pcsupport.lenovo.com/ie/en/p...loads/ds502355
    And then flash with chip with this bios ?
    Which chip do I need to make a backup of and rewrite with the new bios bin file , the one by the ram or the one by the USB C port ?
    I'll make a backup of both chips just in case .
    • Bizb9l21
      • Jan 2023
      • 26
      • Usa
      i have damped the 1MB and the 16MB chips (please see attached)
      please if you need any more info please let me know .
      Brand: Lenovo t480
      Type: 20L5-000UUS
      s/n: PF-1P3ZT2 ---- 19/04
      processor type: i7
      issue: only melody no boot code 0285
      Please see attached dumps, any help would be greatly appreciated.
      i am also not sure if it has any bios lock if it dose and you can help with removing the password that would be amazing !
      thank in advance !
      • Bizb9l21
        • Jan 2023
        • 26
        • Usa
        Update : got a working bios all clean , boots up not locked but when I take the SSD with caddy from my working t470 and installed it in my t480 it won't boot , power on to black screen.
        When SSD cable is connected it boots fine without SSD , it's ONLY when SSD is connected that it won't boot now .
        The SSD is working with windows, tested several times.
        Any ideas what it could be ?
        • Bizb9l21
          • Jan 2023
          • 26
          • Usa
          Any leads ?
          • ThinkpadMounty
            • Sep 2023
            • 14
            i got the the 0285 error code on a T480 20L5 too can anyone help me clean my bios files attached
          • ThinkpadMounty
            • Sep 2023
            • 14
            Serial number 20L5-000WUS PF-16746D
            • ThinkpadMounty
              • Sep 2023
              • 14
              • hoaca388
                Badcaps
                • Jan 2022
                • 11687
                T480 Laptop (ThinkPad) - Type 20L5
                • ThinkpadMounty
                  • Sep 2023
                  • 14
                  so i do i only need to change the main bios chip program not the small one?
                  • Biga73
                    • Nov 2017
                    • 25
                    • Ukraine
                    Please, same problem. 0285 error code. Bios attached. Type 20L6-S1DV00 S/N:PF-1KV0UP
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11687
                      T480 Laptop (ThinkPad) - Type 20L6
                      • BlackBird669
                        • Apr 2024
                        • 4
                        • Austria
                        Hello hoaca388,
                        i'm also facing the problem/code 0285, can you help me here?
                        BIOS attached. Type: 20L6-S1UQ04 S/N:PF-1FH5PP 18/10
                        Thank you very much!
                        Best Regards
                        • peste
                          peste commented
                          Editing a comment
                          Don't post pictures unless asked..
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11687
                        Originally posted by BlackBird669
                        Hello hoaca388,
                        Best Regards
                        Wrong chip.
                        • BlackBird669
                          • Apr 2024
                          • 4
                          • Austria
                          Sorry, here should be the right one.
                          Thanks a lot!
                          Best Regards
                          • BlackBird669
                            • Apr 2024
                            • 4
                            • Austria
                            peste
                            sorry thanks for delete.
                            hoaca388 do you need any additional information? Thanks!
                            Best Regards
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11687
                              peste
                              Best Regards
                              Here
                              • BlackBird669
                                • Apr 2024
                                • 4
                                • Austria
                                Here
                                Thank you very much! It works again
                                • Xargon1975
                                  • Apr 2025
                                  • 13
                                  • España
                                  Any leads ?
                                  Were you able to fix it? I have the same problem
                                  • Drakgon
                                    Lenovo E590 - no boot after repair USB-C connector, only melody
                                    by Drakgon
                                    Hallo friends, I have problem with Lenovo E590. After repair USB-C connector notebook can´t boot. I disassembly the laptop, and wait cca two weeks for new connector. Now I resoldering connetor and after press power on button only beep some melody and I analyse it witch LenovoPCDiagnostik App as error 0284 (TCG-compliant functionality-related error). I try flash some BIOS from peste moderator from this formu, but this is no working. Do you have some idea for fix this problem please? I resoldering the connector carefully and i have practice with it. I test charging with USB-C powermeter, and this
                                    12-18-2024, 10:41 AM
                                  • Luke Anders
                                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                    by Luke Anders
                                    A few details about the laptop itself:
                                    Name: Lenovo Legion 5
                                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                    BIOS Version: GKCN60WW
                                    EC Version: GKEC65WW
                                    Serial Number: PF39AQ7Z
                                    Board Model: NM-D562 Rev 3.0
                                    RAM: 16GB Installed, DDR4 (brand new)
                                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                    I bought this laptop recently from eBay as a faulty device....
                                    10-12-2024, 05:13 AM
                                    Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                    09-06-2024, 03:21 PM
                                    09-06-2024, 02:34 PM
                                    09-06-2024, 02:28 PM
