Lenovo E590 - no boot after repair USB-C connector, only melody
  • Drakgon
    • Nov 2020
    • 23
    • Czech Republic
    Hallo friends, I have problem with Lenovo E590. After repair USB-C connector notebook can´t boot. I disassembly the laptop, and wait cca two weeks for new connector. Now I resoldering connetor and after press power on button only beep some melody and I analyse it witch LenovoPCDiagnostik App as error 0284 (TCG-compliant functionality-related error). I try flash some BIOS from peste moderator from this formu, but this is no working. Do you have some idea for fix this problem please? I resoldering the connector carefully and i have practice with it. I test charging with USB-C powermeter, and this is ok...
    Thank you so much for your reply!
    Type: Lenovo E590 20NB-001YMC
    S/N: PE-1GGEUV 19/08
  • FriedFred
    • May 2024
    • 141
    This sounds like you did something more than just to replace the connector... Did you disconnect the BIOS battery? Still have the failure? Where do you see this "error 0x0284" if the laptop can't start?
    • Drakgon
      • Nov 2020
      • 23
      • Czech Republic
      Hallo,
      The bios battery was disconnected for about 2 weeks before the new connector arrived. I try disconnect this battery again, but it still doesn't work. I really just resoldered the connector like I always do. ​I use iOS app "LenovoPCDDiagnostik" for listen the melody and this app say "error 0284 (TCG-compliant functionality-related error)."
      • Drakgon
        • Nov 2020
        • 23
        • Czech Republic
        does anyone have any ideas?​
        Thank you!
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          I would try the usual, try other memories swap them or leave only one, I would start with this before making a storm in a glass of water
          • drscoot
            usbc connector replacement on mobile
            by drscoot
            I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
            The battery is still charging (red led), but no power on.
            I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
            07-13-2025, 02:37 PM
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
          • Luke Anders
            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
            by Luke Anders
            A few details about the laptop itself:
            Name: Lenovo Legion 5
            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
            BIOS Version: GKCN60WW
            EC Version: GKEC65WW
            Serial Number: PF39AQ7Z
            Board Model: NM-D562 Rev 3.0
            RAM: 16GB Installed, DDR4 (brand new)
            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
            I bought this laptop recently from eBay as a faulty device....
            10-12-2024, 05:13 AM
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • 5mall5nail5
            Help identifying connector for ASUS 4090 Strix RGB LED connector
            by 5mall5nail5
            Hi All -
            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
            05-04-2025, 07:47 AM
