microsoft Go 2 1927 Bios Unlock way
 try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 some one help me to unlock surface go 2 part number DA0Z93MBAE0 REV E
 s\n 0B368F6222837H
 Attached FilesComment
 hi tryAttached FilesComment
 https://www.badcaps.net/donateComment
 Post the blocked one so we can unblock it...
 The bios chip must be unsoldered from the board before writing or reading..
 do not use the clip, you may have errors..if you do not have anything to unsolder it with,
 solder wires between the programmer and the bios chip..
 you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Model : Microsoft Surface Laptop go 2 LTE 1927
 Issue : Bios Password
 SN : 017950604351Attached FilesComment
							Channel: BIOS Requests ONLY!
			by tekky5Hello Friends! Trying to dump bios bin for Microsoft Surface 3 to recover UEFI password but running into error when running FPTW64 in CMD in Administrator mode:
 More Details:Code:fptw64.exe -bios -d dump.bin Intel (R) Flash Programming Tool Version: 13.0.37.1556 Failed to Initialize driver for accessing PCI device. Error 51: Could Not access PCI device. Error 51: Could not access PCI device. Error 64: Failed to initialize SPI interface. FPT Operation Failed.
 1. I don't know the UEFI password, dumping bios to recover...-
			by ahmypcHi. I have a surface pro 8 1983 device with locked bios. Bios settings are disabled. I think DFCI is enabled. Can you help me solve the problem.Thanks.
 Serial: 0F00AQL214601J...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
 Thanks-
- Loading...
 Thank u
 Thank u
