X270 (20K5-S27L00) troubleshooting
  • Chester Drawers
    • Sep 2022
    • 3
    Hi.
    Can anyone recommend a next step here please?
    Bought an X270 (20K5-S27L00) which completed POST but came supervisor password locked. My attempts to make the machine useable have not gone to plan.
    1.Desoldered the 25Q128FVSQ BIOS and dumped a copy using a CH341, SOIC to DIP adaptor and Asprogrammer.
    The CH341A is version 1.7 (selectable voltage) and I used a reasonable SOIC to DIP adaptor, not one of those high resistance leads with a clothes peg on the end...
    2.Autopatched the BIOS and refitted to the motherboard.
    On POST I was then greeted by a series of beeps which the Lenovo diagnostics (Android) app identified as “code 0285 TCG Compliant functionality error (might be TPM initialization failure)”.
    3.Removed the BIOS for a second time and restored the original version. No change – same beep code on POST.
    4.Removed BIOS for the third time and applied a clean ME version downloaded from here https://www.badcaps.net/forum/showth...t=70596&page=2 Also attached to this post. This proved to be a bad idea as I didn't check which revision of X270 board it was for.
    Re-fitted BIOS to motherboard. No POST. Just the 3 flashes when the charger is connected. No beep codes. No backlight.
    5.Removed BIOS for a fourth time. Restored original BIOS. Re-fitted to motherboard. Again, just LED flashes and fan initialization when connecting the charger. Pressing the power button spins the fan 3 times but that's it.
    No physical damage to solder pads or PCB – worked with SMD for 27 years. Kapton covering up everything else. All 3 batteries disconnected whilst soldering.
    Foolishly I only dumped one copy of the original BIOS. No excuses here.
    Original, patched and clean ME versions attached to this post.
    Thank you.
  • reformatt
    • Feb 2020
    • 1482
    Re: X270 (20K5-S27L00) troubleshooting
    I think your original BIOS is ok as it opens fine in UEFI tool. The pre-reqs for the DXE injection patch are to
    Disconnect the main and CMOS batteries until original BIOS is returned.
    Remove any SSD if present.
    Tape down anti-tamper switch if present.
    The DXE injection hack alters the MEC firmware, because this is where the supervisor password is stored. At this point since you've returned your original BIOS and not working, I'd be checking the MEC firmware next. There are threads here how to do that via JTAG, but you'll need an appropriate programmer to do that (SVOD3 etc).
    • Chester Drawers
      • Sep 2022
      • 3
      Thanks for inspecting the upload and the constructive suggestions.
      I can confirm that all 3 batteries were removed for the duration of my unsuccessful efforts and that the anti tamper switch was indeed taped down.
      I'm away from workshop facilities for a few days, but will look into MEC firmware and report back on my return. I have access to a JTAG as they're used to program CPLDs at work.
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • Timeeez
        X270 - Bios flashing help
        by Timeeez
        I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
        Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
        11-30-2022, 05:17 PM
      • JoWed
        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
        by JoWed
        Hello Community,
        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
        07-01-2025, 09:32 AM
      • TraJikar Mac
        [HELP] G712LWS BIOS capsule
        by TraJikar Mac
        I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
        The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
        You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
        Also, I uploaded a backup file for the bios that I extracted by using CH341A...
        06-11-2025, 01:35 PM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
