Bios .BIN for Toshiba P855-34k ?
  • zioricci
    • Jan 2023
    • 125
    • Italy
    I've had a Toshiba P855-34k in my drawer for a few years which stopped at the Toshiba logo when started without going forward and without being able to even enter the bios with F2 F1 Esc Del etc... I tried them all, CMOS reset etc. .. and checked all the voltages of the important chips on the motherboard and they are correct. Thinking that the bios was corrupted, with CH341A programmer I tried to load the 2 -BIN files that I found on the internet but now I don't even see the Toshiba logo :-D Checking with Winhex I saw that the EC file has no header and is full of FF bytes up to location 00160000, therefore empty for 3/4 while the MAIN one maybe has a header, maybe... a lot of gratitude to whoever helps me
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Re: Bios .BIN for Toshiba P855-34k ?
    Originally posted by zioricci
    Upload your Original Backup here, write your Device Short Model and Serial Number.
    all donations are welcome,
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      DUMPS OK دامب
      • zioricci
        • Jan 2023
        • 125
        • Italy
        Originally posted by aboumohamed
        DUMPS OK دامب
        Thanks but it's just the two .BIN files I have that I was talking about. I don't understand what the .ROM file is for.
        • zioricci
          • Jan 2023
          • 125
          • Italy
          I tried to upload the backup but it says they are Invalid files
          Model: Toshiba P855-34k
          Where can i find the serial number on the motherboard? There are several codes scattered here and there
          • hardware1
            • Sep 2021
            • 2936
            • N/A
            You need to Compress the files before upload it, use WinRAR or 7-ZIP.
            Serial Number and Model will be written on the Laptop Bottom Cover, not on the Motherboard.
            • zioricci
              • Jan 2023
              • 125
              • Italy
              Ok.
              Model: Satellite P855-34K
              Serial number: 5D063411K
              • hardware1
                • Sep 2021
                • 2936
                • N/A
                Ok.
                Here's your New BIOS, it's a Virgin BIOS from Toshiba.
                If the Device works fine, we can transfer your DMI.
                By the way, the Model Number in your Dump is "SATELLITE P850".
                • zioricci
                  • Jan 2023
                  • 125
                  • Italy
                  I'll try it in a while and let you know, thanks in advance. I wanted to ask, don't you find it strange that the 2MB file starts at 0016000 and has all FF up to that point ?
                  • hardware1
                    • Sep 2021
                    • 2936
                    • N/A
                    Did you mean (160000h)? No it's normal, because your BIOS file is divided on the 2 Chips.
                    • zioricci
                      • Jan 2023
                      • 125
                      • Italy
                      00160000 is the hexadecimal offset from the start of the EC file. I thought each bios had separate functionality and the EC one worked in symbiosis with Super I/O
                      • hardware1
                        • Sep 2021
                        • 2936
                        • N/A
                        No, they complement each other. Maybe the SIO has another Chip or its Firmware is inside it.
                        • zioricci
                          • Jan 2023
                          • 125
                          • Italy
                          ok. Another quenstion...since the P855 identifier is in the MAIN file and since I have two boards, one P855 and the other P850, I noticed that at the address 0015F000 of the 16_855.bin file that I posted there is a sequence of codes, BY29N-GGJP3-*****-*****-****-****, do you know if it is possible to understand from these codes whether the file refers to the P855 or the P850 ?
                          • hardware1
                            • Sep 2021
                            • 2936
                            • N/A
                            It's your OEM Windows Key, you shouldn't Post it on public.
                            • zioricci
                              • Jan 2023
                              • 125
                              • Italy
                              oh my gosh
                              • zioricci
                                • Jan 2023
                                • 125
                                • Italy
                                Wow, with your two files I managed to reboot my old laptop, it was the 2MB bios that was corrupted. Thank you very much.
                                • hardware1
                                  • Sep 2021
                                  • 2936
                                  • N/A
                                  You're Welcome.
                                  • zioricci
                                    • Jan 2023
                                    • 125
                                    • Italy
                                    I have a problem, with the battery starts with the charging cable stuck on Toshiba logo.
                                    Yesterday I connected the charging cable and main battery together and it started up to Windows but today I removed the battery and tried only with the charging cable but it stuck at the Toshiba logo without going on, but at least I can log in in the bios with F2, which it didn't do before.
                                    • hardware1
                                      • Sep 2021
                                      • 2936
                                      • N/A
                                      Therefore, what's your Problem now? The device stuck on Logo and doesn't boot to Windows or you can't go into the BIOS menu?
                                      Have you tried to remove the CMOS Battery? Did you checked with another HDD?
                                      • zioricci
                                        • Jan 2023
                                        • 125
                                        • Italy
                                        The problem now is that if I power only with the charging cable, it hangs on the Toshiba Logo while if I remove the cable and put the main battery, I get to Windows boot without problems, so I don't think it's the disk. I also took out the CMOS battery and shorted the plus and minus on the motherboard (no on the battery).
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
