I need BIOS for ASUS Zephyrus GA503QR-211.ZG15/GA503QS
  • mixtape87
    • Apr 2020
    • 28
    Originally posted by noname2024
    wbt -c cnfg /w dd 7e
    What is Now the Command i have to use to bring back the rgb light on my keyboard?
    • mixtape87
      • Apr 2020
      • 28
      use tools WBT-313
      C:\WBT-313\X64\Keyboard_Light_enable.bat
      Or can you send me quick guide where i can read what i have to do? caause the link you guys posted doesnt tell me much ecxept the name of the wbt tool
      • mixtape87
        • Apr 2020
        • 28
        So tried the last days to use Wbt and always getting the error code 255
        • mixtape87
          • Apr 2020
          • 28
          Originally posted by volinakis
          yep, as I suspected ...
Name:	Screen Shot 2024-12-29 at 13.10.52.png
          Or it there a possibility that you make me an new fresh correct bios file which one I just flash and the rgb is working?
          • volinakis
            • Jan 2021
            • 2733
            • N/A
            I told you, post a picture with QR code from working motherboard to see what bios you need
            • mixtape87
              • Apr 2020
              • 28
              Your absolutely right didn’t read that part of your post properly sorry for that! Here is the Data matrix code from the Mainboard
              • volinakis
                • Jan 2021
                • 2733
                • N/A
                #27
                try
                • mixtape87
                  • Apr 2020
                  • 28
                  try
                  Thank you, quick question can I put it on a stick and flash it through out the bios or with the flasher ?
                  • volinakis
                    • Jan 2021
                    • 2733
                    • N/A
                    #29
                    nope, you have to write bios chipset
                    • volinakis
                      • Jan 2021
                      • 2733
                      • N/A
                      #30
                      I see there is a fix for RGB kb in drivers, download it and install
Name:	Screen Shot 2025-01-03 at 11.54.18.png
                      • mixtape87
                        • Apr 2020
                        • 28
                        I installed that already but didn’t changed anything so I will try to flash the new bios and then check it out
                        • mixtape87
                          • Apr 2020
                          • 28
                          try
                          tried it, same no changes in the keyboard light still just red.
                          • volinakis
                            • Jan 2021
                            • 2733
                            • N/A
                            #33
                            sorry, I am out of ideas. Try run again the fix for RGB kb with new bios.
                            • mixtape87
                              • Apr 2020
                              • 28
                              Tried that also and then a cmd windows pops up and there is written the mainboard : GA503QS and than followed by skipped GA53QS
                              • mixtape87
                                • Apr 2020
                                • 28
                                What if I try to Flash the backup from the og board? Maybe that would help ? Like is Said I tried your bin and the Keyboard fix from asus
                                • mixtape87
                                  • Apr 2020
                                  • 28
                                  And i reinstalled the dead og board and the keyboard lights up in all the rgb colors but not booting cause of the fried
                                  cpu so Iam really really confused and don’t know what the problem is.
                                  • mixtape87
                                    • Apr 2020
                                    • 28
                                    try
                                    In this bios there is another SN, can you change the SN to the original one I posted?
                                    • volinakis
                                      • Jan 2021
                                      • 2733
                                      • N/A
                                      #38
                                      well, is so simple, open hex editor, Find&Replace.
Name:	Screen Shot 2025-01-11 at 02.26.09.png
                                      • mixtape87
                                        • Apr 2020
                                        • 28
                                        Thank you very much I did not know that it is so simple next time I will definitely do that 😁
                                        • mixtape87
                                          • Apr 2020
                                          • 28
                                          Click image for larger version  Name:	Screen Shot 2025-01-11 at 02.26.09.png Views:	22 Size:	44.5 KB ID:	3545891
                                          Nothing worked, I reinstalled the dead mainboard and after i press the power button the keyboard lights up in rgb after swapping to the replacement motherboard its still just simple red light and nothing changes. i am really desperate and don´t know what am i doing wrong here. has anybody an idea or can help me to fix this?​
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                            ASUS ROG GA503QS-HQ004T Notebook Zephyrus G15 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GA503QS-HQ004T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA503QS-HQ004T boardview and GA503QS-HQ004T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 10:50 PM
                                            ASUS ROG GA503QS-XS98Q-WH Notebook Zephyrus G15 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GA503QS-XS98Q-WH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA503QS-XS98Q-WH boardview and GA503QS-XS98Q-WH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 10:20 PM
                                            ASUS ROG GA503QS-HQ003T Notebook Zephyrus G15 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GA503QS-HQ003T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA503QS-HQ003T boardview and GA503QS-HQ003T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 10:00 PM
                                            ASUS ROG GA503QS-HQ020T Notebook Zephyrus G15 Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GA503QS-HQ020T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GA503QS-HQ020T boardview and GA503QS-HQ020T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
