HP 840 G6 Endpoint Security Controller reported on Boot Screen
    • 20740
    Originally posted by rickjansen01
    Hello smdflea
    here the ec file for the endpoint error
    5CG0338SS1
    Here. Your backup is 16,385KB and it should be 16,384KB , ive already mentioned that you might be choosing the wrong chip type OTP ! .If you open your 16,385KB backup with RCUnlocker it will fail as it needs the correct filesize
    • rickjansen01
      • Feb 2016
      • 129
      • nederland
      #42
      Hello Smdflea
      it works thanks for the support
      • arif3203
        • Feb 2021
        • 55
        • Banyumas
        #43
        Halo I have a Laptop that has a Endpoint Security Controller Problem.
        Can it be removed?​
        HP 840 G6
        SN: 5CG0278SL8
        • hoaca388
          Badcaps
          • Jan 2022
          • 11662
          #44
          Can it be removed?​
          HP 840 G6
          SN: 5CG0278SL8
          • Bios Cracker
            • Oct 2024
            • 314
            • India
            #45
            Can it be removed?​
            HP 840 G6
            SN: 5CG0278SL8
            Try and update.
            • arif3203
              • Feb 2021
              • 55
              • Banyumas
              #46
              Thanks master hoaca388 and Master Bios Cracker file working
              • Lovro25
                • Jan 2023
                • 11
                • Croatia
                #47
                Hello, I have the same problem can someone please help
                HP EliteBook 840 G6
                SN: 5CG9463MW5​
                  • 20740
                  HP EliteBook 840 G6
                  SN: 5CG9463MW5​
                  Try this patcher -> https://www.badcaps.net/forum/troubl...security-error
                  • Ismail-U50
                    • Jan 2022
                    • 85
                    • Nigeria
                    #49
                    Please help me repair my bios file, is not come up after power led blink white and orange and have try some file in the thread but not perfect enough some start after some time fan spin fast no image
                    some display it will show up ......"Security End Point" Please help me with perfect bios with no complain
                    In case u need my backup. He is it down attached with info
                    HP Elitebook 840 G6
                    Board Number :6050A3022501-MB-A01
                    S/N: 2TK9490LWF
                      • 20740
                      Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                      Read the post above yours and post 16, try to fix it yourself. If editing or using the script doesn`t work then clean the ME firmware.
                      • Ismail-U50
                        • Jan 2022
                        • 85
                        • Nigeria
                        #51
                        I did not see any responds on that....why i re-post again.
                        please any help regard complain?
                        • peste
                          • Dec 2016
                          • 12676
                          • ROMANIA
                          #52
                          you got the answer above..stop posting everywhere..
                          • Junior††
                            a2251 820-01949-a boot looping after screen replacement
                            by Junior††
                            not sure how it happened but after replacing the screen on a2251 macbook it:
                            fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
                            thermal camera shows these are getting quite hot although i'm not sure what do to.
                            i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
                            07-15-2025, 09:17 PM
                          • kolebbk
                            HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                            by kolebbk
                            Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                            HP Endpoint Security Controller problem
                            there is a problem with the hp endpoint security controller on the unit
                            I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                            09-04-2024, 12:44 AM
                          • arbitarytwist
                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                            by arbitarytwist
                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                            03-01-2025, 01:16 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • fede77
                            Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                            by fede77
                            Notebook HP ProBook 450 G8
                            ProdID 2K8L1LT#AC8
                            Mother: DAX8QAMB8D0 REV D
                            The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                            03-10-2025, 07:12 AM
