HP 840 G6 Endpoint Security Controller reported on Boot Screen
    • 21197
    Originally posted by YOUNES MIH
    I have a Laptop 840 g6 that has a Endpoint Security Controller Problem.
    Can it be removed?
    end late display 30s
    Clean the ME firmware https://www.badcaps.net/forum/troubl...22#post1622422
    • YOUNES MIH
      • Nov 2017
      • 45
      • ALGERIE
      • Ghamidi
        • Mar 2020
        • 303
        • France
        Can it be removed?
        try this file and Feedback please
        • ridouane
          • Mar 2019
          • 19
          • casablanca
          Please help me with endpoint security controller problem
          HP Elitebook 840 G6
          SN : 5CG9442CPM
          Product ID :4WG30AV
          Thanks​
        • ridouane
          • Mar 2019
          • 19
          • casablanca
          thank you very much my brother SMDFlea
          for sharing information. I followed the instructions but it gives me the following message:​
            SMDFlea commented
            Editing a comment
            The error was probably because you had a double file extension endpoint.bin.bin .By default windows hides known file extensions, you can disabe that setting in folder options
        • Ghamidi
          • Mar 2020
          • 303
          • France
          #26
          HP Elitebook 840 G6
          SN : 5CG9442CPM
          Product ID :4WG30AV
          Thanks​
          Try
          • Carl Angelo Aposaga
            • Jan 2024
            • 3
            • Philippines
            #27
            hello please help
            please help with endpoint security controller problem on boot
            hp elitebook 840 g6
            ProdID 9JW45UC#UUF
            sn# 5CG01GP73
          • shiyab
            • Sep 2023
            • 1506
            • india
            #28
            Originally posted by Carl Angelo Aposaga
            hello please help
            hp elitebook 840 g6
            ProdID 9JW45UC#UUF
            sn# 5CG01GP73
            post mani backup bios
              • Jan 2024
              • 3
              • Philippines
              #29
              hello please help
              hp elitebook 840 g6
              ProdID 9JW45UC#UUF
              sn# 5CG01GP73
              thanks in advance
              • hoaca388
                Badcaps
                • Jan 2022
                • 11901
                #30
                thanks in advance
                • YOUNES MIH
                  • Nov 2017
                  • 45
                  • ALGERIE
                  #31
                  HP Elitebook 840 G6 (EndPoint Security Controller Problem)
                  6050a2945601-mb-a01
                  SN: 5CG9510R33​
                    SMDFlea commented
                    Editing a comment
                    post moved to 840 G6 topic.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11901
                  #32
                  6050a2945601-mb-a01
                  SN: 5CG9510R33​
                  • rickjansen01
                    • Feb 2016
                    • 129
                    • nederland
                    #33
                    Hello
                    I also need help whit endpoint error
                    serial 5CG0338SS1
                    840 g6
                    • peste
                      • Dec 2016
                      • 12973
                      • ROMANIA
                      #34
                      Originally posted by rickjansen01
                      Hello
                      serial 5CG0338SS1
                      840 g6
                      read..
                      https://www.badcaps.net/forum/troubl...security-error
                      • Bios Cracker
                        • Oct 2024
                        • 315
                        • India
                        #35
                        Try this file....
                        Step 1. Flash EC + This Patch file. Then Boot blank or black display will appear.
                        Step 2. Flash Only Your Main Dump File.
                        Hope that will solve the endpoint error.
                        • 21197
                        Hello
                        serial 5CG0338SS1
                        840 g6
                        Your bios is 32,769KB and should be 32,768KB ,i suspect the extra code has been added because you chose an OTP chip, you should choose a non OTP chip then it won`t add any extra .
                        • rickjansen01
                          • Feb 2016
                          • 129
                          • nederland
                          #37
                          hello
                          i send the wrong file about the endpoint problem
                          sorry for that
                          here is the good file
                          5CG0338SS1
                            SMDFlea commented
                            Editing a comment
                            You still have an extra 1KB in your file, did you read this -> Your bios is 32,769KB and should be 32,768KB ,i suspect the extra code has been added because you chose an OTP chip, you should choose a non OTP chip then it won`t add any extra .
                            And did you try what peste linked to, the script patcher will patch it for you, if you follow the instructions.
                            https://www.badcaps.net/forum/troubl...26#post3589426
                        • rickjansen01
                          • Feb 2016
                          • 129
                          • nederland
                          #38
                          hello
                          smdflea
                          i try the patcher white no luck
                          So i ask you guys
                          Regards chris
                            SMDFlea commented
                            Editing a comment
                            post the other chip, the EC_Bios
                        • Bios Cracker
                          • Oct 2024
                          • 315
                          • India
                          #39
                          Originally posted by Bios Cracker
                          Try this file....
                          Yeah it was wrongly tag.
                          • rickjansen01
                            • Feb 2016
                            • 129
                            • nederland
                            #40
                            Hello smdflea
                            here the ec file for the endpoint error
                            5CG0338SS1
                            • Junior††
                              a2251 820-01949-a boot looping after screen replacement
                              by Junior††
                              not sure how it happened but after replacing the screen on a2251 macbook it:
                              fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
                              thermal camera shows these are getting quite hot although i'm not sure what do to.
                              i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
                              07-15-2025, 09:17 PM
                            • kolebbk
                              HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                              by kolebbk
                              Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                              HP Endpoint Security Controller problem
                              there is a problem with the hp endpoint security controller on the unit
                              I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                              09-04-2024, 12:44 AM
                            • arbitarytwist
                              Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                              by arbitarytwist
                              Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                              Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                              03-01-2025, 01:16 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • fede77
                              Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                              by fede77
                              Notebook HP ProBook 450 G8
                              ProdID 2K8L1LT#AC8
                              Mother: DAX8QAMB8D0 REV D
                              The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                              03-10-2025, 07:12 AM
