HP 840 G6 Endpoint Security Controller reported on Boot Screen
    replied
    Originally posted by Ismail-U50 View Post
    some display it will show up ......"Security End Point" Please help me with perfect bios with no complain
    Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
    Read the post above yours and post 16, try to fix it yourself. If editing or using the script doesn`t work then clean the ME firmware.
  • Ismail-U50
    replied
    Please help me repair my bios file, is not come up after power led blink white and orange and have try some file in the thread but not perfect enough some start after some time fan spin fast no image
    In case u need my backup. He is it down attached with info
    HP Elitebook 840 G6
    Board Number :6050A3022501-MB-A01
    S/N: 2TK9490LWF
    replied
    Originally posted by Lovro25 View Post
    Hello, I have the same problem can someone please help
    HP EliteBook 840 G6
    SN: 5CG9463MW5
    Try this patcher -> https://www.badcaps.net/forum/troubl...security-error
  • Lovro25
    replied
    HP EliteBook 840 G6
    SN: 5CG9463MW5
  • arif3203
    replied
    Thanks master hoaca388 and Master Bios Cracker file working
  • Bios Cracker
    replied
    Originally posted by arif3203 View Post
    Halo I have a Laptop that has a Endpoint Security Controller Problem.
    Can it be removed?
    HP 840 G6
    SN: 5CG0278SL8
    Try and update.
  • hoaca388
    replied
    Can it be removed?
    HP 840 G6
    SN: 5CG0278SL8
  • arif3203
    replied
    Can it be removed?
    HP 840 G6
    SN: 5CG0278SL8
  • rickjansen01
    replied
    Hello Smdflea
    it works thanks for the support
    replied
    Originally posted by rickjansen01 View Post
    Hello smdflea
    here the ec file for the endpoint error
    5CG0338SS1
    Here. Your backup is 16,385KB and it should be 16,384KB , ive already mentioned that you might be choosing the wrong chip type OTP ! .If you open your 16,385KB backup with RCUnlocker it will fail as it needs the correct filesize
  • rickjansen01
    replied
    Hello smdflea
    5CG0338SS1
  • Bios Cracker
    replied
    Originally posted by Bios Cracker View Post
    Try this file....
    Step 1. Flash EC + This Patch file. Then Boot blank or black display will appear.
    Step 2. Flash Only Your Main Dump File.
    Hope that will solve the endpoint error.
    Yeah it was wrongly tag.
    commented on 's reply
    post the other chip, the EC_Bios
  • rickjansen01
    replied
    hello
    smdflea
    i try the patcher white no luck
    So i ask you guys
    Regards chris
    You still have an extra 1KB in your file, did you read this -> Your bios is 32,769KB and should be 32,768KB ,i suspect the extra code has been added because you chose an OTP chip, you should choose a non OTP chip then it won`t add any extra .
    And did you try what peste linked to, the script patcher will patch it for you, if you follow the instructions.
    https://www.badcaps.net/forum/troubl...26#post3589426
  • rickjansen01
    replied
    hello
    i send the wrong file about the endpoint problem
    sorry for that
    here is the good file
    5CG0338SS1
    quoting peste ? ,i`m sure you meant to quote rickjansen01
    replied
    Hello
    I also need help whit endpoint error
    serial 5CG0338SS1
    840 g6
  • Bios Cracker
    replied
    Try this file....
  • peste
    replied
    Hello
    serial 5CG0338SS1
    840 g6
    read..
