HP 840 G6 Endpoint Security Controller reported on Boot Screen
  • peste
    • 14047
    • ROMANIA
    #61
    Originally posted by tim9
    I was able to find some related threads , i will try that first - if that does not work , will ask for help again. Thanks !!
    https://www.badcaps.net/forum/troubl...or#post3325398
    post S/N, full name and model, motherboard model, ..product number,,etc.
    • noname2024
      • Aug 2024
      • 295
      • CỎ MỸ XỊN
      #62
      you flash
      • Junior††
        a2251 820-01949-a boot looping after screen replacement
        by Junior††
        not sure how it happened but after replacing the screen on a2251 macbook it:
        fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
        thermal camera shows these are getting quite hot although i'm not sure what do to.
        i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
        07-15-2025, 09:17 PM
      • kolebbk
        HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
        by kolebbk
        Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
        HP Endpoint Security Controller problem
        there is a problem with the hp endpoint security controller on the unit
        I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
        09-04-2024, 12:44 AM
      • arbitarytwist
        Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
        by arbitarytwist
        Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
        Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
        03-01-2025, 01:16 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • erdos
        My pc boot with a blank screen
        by erdos
        greetings
        My old homebuilt pc won't boot for some reason, when I pressed power on, I can hear Power supply fan running, but no bios screen, just blank and DVD-rom LED flashing.
        I've switched with a different graphics card (known good) to no avail. the pc is equipped with corsair 550W power supply and a MSI K8N Neo Platinum Mob.
        How do i check which part is the culprit for causing the issue?...
        10-22-2025, 01:33 AM
