Motherboard Vivobook Flip 14 TP401MAR 2.0
  • max7
    • Nov 2015
    • 69
    • sudan
    I need BIOS bin file for 14 TP401MAR 2.0
  • max7
    • Nov 2015
    • 69
    • sudan
    Re: Motherboard Vivobook Flip 14 TP401MAR 2.0
    https://www.badcaps.net/forum/attach...1&d=1679490549
    • max7
      • Nov 2015
      • 69
      • sudan
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Here's your New BIOS, it's a Virgin BIOS from ASUS with your DMI and Windows Key.
        Serial Number: M5N0CV07366419D.
        all donations are welcome,
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • GardevoirForEver
          Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
          by GardevoirForEver
          I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
          Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
          The motherboard of my ASUS...
          11-15-2025, 04:30 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
