HP 8560w password
Re: Find value resistor HP 8560w
Someone else took this backup, I don't know if they are safe or not, but according to the previous repairer, it is safe. I will test and let you know. Only if you can send me a photo of the BIC Bios area so I can see if another piece has been removed Please upload a photo of this motherboard modelComment
Try this tooAttached FilesPremium supporters get full download access and other benefits.
by chriswfrye21Hi everyone,
I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
Model: HP 255R 15.6 inch G10 Notebook PC SK...-
Channel: BIOS Requests ONLY!
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by DudebromanHello Hello,
I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
- Loading...
