bios DA0AM6MB8F1 Dell Inspiron 15-7548
  • coelectron
    • Mar 2014
    • 58
    • Argentina
    Hello dears friend, i looking for this bios for fix this Dell DA0AM6MB8F1 Dell Inspiron 15-7548 UMA Proyect backup the corrupt Bios, thanks for help me
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: bios DA0AM6MB8F1 Dell Inspiron 15-7548
    Here's your New BIOS, try it and let me know the results.
    Service Tag: 4B28B52.
    all donations are welcome,
    • coelectron
      • Mar 2014
      • 58
      • Argentina
      it works but it's a rare situation, i programmed the BIOS, i powered on and it shows me the screen that says press FN + X, then once i try this, don't power on anymore and blink once the power button led
      • coelectron
        • Mar 2014
        • 58
        • Argentina
        finally semi-solved, bad slot memory, thanks.
        • hardware1
          • Sep 2021
          • 2946
          • N/A
          Good to know, You're Welcome.
          • nyknemesis
            • Aug 2012
            • 86
            • romania
            works, Thank you.
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • sahamipoor
              need bios dell Inspiron 17 7000 2-in-1 p42e
              by sahamipoor
              hi...
              i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
              i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
              i updated to latest version and try other version but not working!
              service tag: HCQ3JW2
              i need your kind....
              10-01-2025, 11:10 AM
            • zlr8r
              looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
              by zlr8r
              looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
              cheers
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              MOBO: RO 15 17 WHL 2GB MB / 18706-2
              Attached;
              1. My saved bios using a programmer
              2. Dells Bios updater .exe (v1.16)
              3. Dells Bios recovery file
              4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
              5. Image of ME...
              12-18-2023, 03:08 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • GadgetsFix
              Dell Inspiron 16 5630 BIOS request
              by GadgetsFix
              I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
              • Model: Dell Inspiron 16 5630
              • MainBoard Part Number: 4550SC01C004
              • Laptop Serial No: GKH3JX3
              • DP/N: 0303KM
              • QUAKE N RPL UMA CS MB
              • 213251-2
              • TMN0H$KB
              01-17-2025, 07:38 AM
