Lenovo g50-80 80e5
Lenovo G50-80 (80E5) boots normally (e.g. Windows or Ubuntu).
Processor is Intel Celeron 3205U
Latest BIOS Version is installed: B0NA0WW, 30.09.2016
But the laptop shutdown exactly after 30 minutes (even in BIOS Setup) after startup. Obviously, this is controlled by the BIOS.
Could be a corrupt BIOS (MEI)?.
Does somebody know how to fix that?
Is it required to read, patch and write the BIOS chip UC3 from mainboard? Any suggestions?
Lenovo-G50-80 (80E5)
Mainboard: ACLU3-ACLU4-UMA-NM-A362
S/N: PF072BWH
Attached BIOS works. But laptop shutdown exactly after 30 minutes (even in BIOS Setup) after startup.
Please advise / help. Thanks.Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Thanks. Problem is fixed. Used BIOS bin from post #2 with original DMI data offset 29A000 - 29BFFF.Comment
This is the original biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Lenovo B50-80 Laptop - Type 80EW
https://www.badcaps.net/donateComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by gestalt.exeHi everyone,
My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
Laptop stopped booting entirely.
I used a CH341A programmer to dump the corrupted 16MB BIOS.
i then attempted the following:- Downloaded stock BIOS BHCN39WW from Lenovo
- Trimmed it to 16MB
- Extracted the BIOS region from the corrupted dump
- Extracted the BIOS region from the stock 39WW
- Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
- Injected back my LDGB / DMI
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM - Loading...
