password remove bin file ok
DAH98DMB8B0 REVB bios
Re: DAH98DMB8B0 REVB bios
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
product name: BoD-WDI9
serial: L9PPM22622001538
DMI OFFSET 01228000 to 012282d7
can someone rebuild my bios. it has no display.
i tried from other site the the en25qh256 it works but SSD not detected. i tried clear me my dump it also doesn't work.
i tried copying dmi from my dump to the en25qh256 but SSD it still doesn't Detected. i'm pissed off.
yes i have use this I patched it manually. it doesn't need DMI change it detects SSD.
a little feedback please.
Attached FilesLast edited by rex98; 01-06-2024, 07:34 AM.Comment
Every donation made will go towards server fees and maintenance costs.Comment
Thanks. Thought it would be easier. Lol. Seek and u shall find it sais. I don.t find the chip on the motherboard. Someone can show me the location?
I will unsolder and keep u informed.Comment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
So
Huawei mate d15 2021 BoD-WDI9
I3 11th, 8gb ram, 256gb ssd
Sn L9PPM22729000472
MB - DAH98DMB8B0 REV B
Bios dump from a dumb kid!
Can you remove the password or give me some clean bios please?Attached FilesComment
Send to you, tryAttached FilesComment
Send to you, try again !Attached FilesComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
- Loading...
