DAH98DMB8B0 REVB bios
  • rex98
    • Feb 2023
    • 1297
    • Mandaue CEBU, Philippines
    Originally posted by stiksuri
    Can you tell me how did you do? I don' see my ssd. You pached or you solved from the bin itself? You changed something or what?
    use this flash directly. give feedback.
    • ELOUALI
      • Mar 2022
      • 47
      • BLANCA
      YOU ARE AN ANGEL.
      THANK YOU SO MUCH.
      • Itai
        • Mar 2023
        • South Africa
        hi guys looking for h98d DAH98DMB8B0 REV B HF
        I lost the original bios model NbDE-WDH9
        S/N:NQNPM23306001609
        • janpatirkckaram1992
          • Sep 2020
          • 9
          • Philippines
          NO display can someone help me with this one , deeply appriciated
          SN: l9ppm22624000653
          • Igorek120491
            • Mar 2025
            • Ukraine
            Good day. I ask for help in finding the bios. Huawei mate book d15.
            BoD-WDH9
            S/N:GCGPM22121000173
            DAH98DMB8B0 REVB​
              • 22293
              BoD-WDH9
              DAH98DMB8B0 REVB​
              If you have a backup post it, otherwise try the bios above by rex98
              • lapzlapz
                • May 2016
                • 22
                • kerala
                #27
                DAH98DMB8B0 REV B SOUND NOT WORK
                  • 22293
                  Type the laptop serial number, full name and model, motherboard model, etc.
                  read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                  • alarkm
                    OLD Member
                    • Feb 2015
                    • CAIRO
                    #29
                    SSD FIX, TRY
                    • to5it0
                      by to5it0
                      10-24-2025, 01:35 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • maanee11
                      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                      by maanee11
                      Hello Everyone,
                      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                      In the website, you can only see specs etc.
                      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                      11-08-2025, 04:08 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      Hi everyone
                      09-06-2025, 05:47 PM
                    • Forest79
                      by Forest79
                      07-23-2023, 07:39 AM
