DA0G3KMBCG0 REV G no display
  • peste
    • Dec 2016
    • 13436
    • ROMANIA
    Originally posted by DolphiServiceLTD
    I made a mistake with 0 and O
    Do you know what kind of bios chip this laptop using ?
    I don't know..search on the internet...
    • DolphiServiceLTD
      • Apr 2024
      • 26
      What about the bios file?
        • 21690
        Hello!
        Unfortunately, the bios is damaged (one of the legs is missing) and the programmer does not want to read it. I don't know what kind of model it is. That's why I'm looking for the exact bios model if possible to order it from China and then reprogram it.
        Post a picure of the damaged chip.Even if the leg has broken off flush it could still be possible to solder a very thin wire onto the exposed metal
        • DolphiServiceLTD
          • Apr 2024
          • 26
          On the picture are okay, when we tried to test it on the programmer, the bios wasn't responding at all. So we think it's damaged and will be not able to fix it. So we order one from china, but we need the bios dump file for this model.
          Click image for larger version  Name:	viber_image_2024-06-19_17-51-50-818.jpg Views:	29 Size:	189.9 KB ID:	3293334
          • peste
            • Dec 2016
            • 13436
            • ROMANIA
            the chip seems ok.. remove the chip from the motherboard before writing or reading, if you use the clip you may have errors.. if you don't have anything to remove it, stick wires between the chip and the programmer ..read it again and post the content..at the moment do not buy any chip, try to extract the content from it..
            • jimore
              • Nov 2020
              • 179
              • mexico
              #26
              check again if you wrote the name and model of the laptop correctly and the S/N... post the original bios even if it is corrupted..
              bro another omen nO display help
              model:AX210NGW
              • hoaca388
                Badcaps
                • Jan 2022
                • 12272
                #27
                model:AX210NGW
                Add serial number to article.
                ​https://www.badcaps.net/donate
                • jimore
                  • Nov 2020
                  • 179
                  • mexico
                  #28
                  model:AX210NGW
                  SN# 5cd1455LRK
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12272
                    #29
                    SN# 5cd1455LRK
                    OMEN by HP Laptop 16-b0175TX (5C148PA)
                    • jhodex
                      • Feb 2016
                      • 28
                      • Philippines
                      #30
                      hi good day
                      Omen by HP 16-b0145TX
                      SN: 5CD142NWFD
                      Need help with this file, no display. please repair
                      thank you in advance
                      • danito
                        • Jun 2016
                        • 1069
                        • Romania
                        #31
                        Originally posted by jhodex
                        hi good day
                        SN: 5CD142NWFD
                        try
                          • 21690
                          hi good day
                          SN: 5CD142NWFD
                          The post above yours is a virgin bios. The bios version is the same as yours, BID088F4 .You can use that bios and then copy your DMI info to it, or you can get and extract a virgin bios yourself by reading the HP guides.
                          [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                          [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
                          Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
                          Offsets: 701000 - 70203F and 786000 - 78603F
                          HxD Hex editor https://mh-nexus.de/en/hxd/​
                          • abdulhashim
                            • Jul 2015
                            • 22
                            • UAE
                            #33
                            Hello
                            hp omen
                            16-b0005dx
                            sn: 5CD143DJQQ
                            problem after update bios corrupted
                            pleas help to fix this
                            • qayyum786
                              • Aug 2018
                              • 1959
                              • INDIA
                              #34
                              Originally posted by abdulhashim
                              Hello
                              hp omen
                              16-b0005dx
                              sn: 5CD143DJQQ
                              Dmi @ 701000-7020FF
                              Key win @ 786000-78602F
                              • abdulhashim
                                • Jul 2015
                                • 22
                                • UAE
                                #35
                                Originally posted by qayyum786
                                Dmi @ 701000-7020FF
                                Sorry this file is no display
                                old file display coming and error message showing then black screen
                                this file is completely no display..
                                • reparacipo
                                  • Jun 2018
                                  • 31
                                  • argentina
                                  #36
                                  Hi guys, could you help me repair this BIOS? I have a black screen.
                                  HP Omen 16-b0005dx
                                  SN# 5CD143DJBX
                                    • 21690
                                    HP Omen 16-b0005dx
                                    SN# 5CD143DJBX
                                    Read post 32 ,you have the same BID ,same DMI offsets.
                                    • hoangmusicbt
                                      • Feb 2023
                                      • Việt Nam
                                      #38
                                      Can you guys tell me if this product can only be powered by an adapter? Thank you.
                                      • peste
                                        • Dec 2016
                                        • 13436
                                        • ROMANIA
                                        #39
                                        Be more explicit...what did you mean?
