DA0G3KMBCG0 REV G no display
  • lesterbrazal
    • Aug 2011
    • 38
    hp omen board DA0G3KMBCG0 REV G no diplay here is the backup thanks
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: DA0G3KMBCG0 REV G no display
    Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key, try it.
    Serial Number: 5CD1455JY5.
    all donations are welcome,
    • lesterbrazal
      • Aug 2011
      • 38
      thank you very much i will update you if its working
      • lesterbrazal
        • Aug 2011
        • 38
        sorry still no display
        • TonyCajeta
          • May 2022
          • 17
          • Mexico
          Are you sure it is a BIOS related problem?
          Have you tested the BIOS input voltage? GPU VCore? Tried connecting a monitor via HDMI?
          Any error code?
          • lesterbrazal
            • Aug 2011
            • 38
            yes
            • jimore
              • Nov 2020
              • 182
              • mexico
              here's your new bios, it's a virgin bios from hp with your dmi and windows key, try it.
              Serial number: 5cd1455jy5.
              omen model ax20ingw da0g3kmbcg0 rev g
              bro pls help me no display..thanks. clean this bios.
              • hardware1
                • Sep 2021
                • 2949
                • N/A
                Try the file in Post #2, it's a Virgin BIOS and should works fine if your device problem was related to the BIOS.
                • jimore
                  • Nov 2020
                  • 182
                  • mexico
                  still no display post#2
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    Write your device Full Model Number and Serial Number.
                    • jimore
                      • Nov 2020
                      • 182
                      • mexico
                      model AX20INGW
                      OMEN BY HP LAPTOP; 16-B0145TX
                      SN# 5CD142NWFB
                      BRO.
                      • peste
                        • 13924
                        • ROMANIA
                        model AX20INGW
                        SN# 5CD142NWFB
                        BRO.
                        bios extracted from HP site update
                        DMI 701000 - 7020FF
                        KEYWIN 786000 - 78603F
                        if it doesn't work, either you didn't write it correctly or the laptop has another problem..
                        • phamduy221
                          • Jan 2021
                          • 55
                          • vietnam
                          model AX20INGW
                          SN# 5CD142NWFB
                          BRO.
                          you can try this bios
                          • DolphiServiceLTD
                            • Apr 2024
                            • 28
                            Hello! I need bios for HP OMEN 16-b0024nq / SN# 5CD204FOOK
                            Also what type of bios chip they use? My bios it's dead.. And we cant find the same anywhere.
                            Thank you in advance!
                            Best regards!
                            • peste
                              • 13924
                              • ROMANIA
                              Best regards!
                              check again if you wrote the name and model of the laptop correctly and the S/N... post the original bios even if it is corrupted..
                              • DolphiServiceLTD
                                • Apr 2024
                                • 28
                                Hello!
                                Unfortunately, the bios is damaged (one of the legs is missing) and the programmer does not want to read it. I don't know what kind of model it is. That's why I'm looking for the exact bios model if possible to order it from China and then reprogram it.
                                • peste
                                  • 13924
                                  • ROMANIA
                                  Hello!
                                  I'm interested in the model and the S/N of the laptop if you wrote it correctly .. check it once..
                                  • DolphiServiceLTD
                                    • Apr 2024
                                    • 28
                                    SN#5CD204F00K - yes, sorry my mistake. I wrote the incorrect SN Number
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      well... isn't it the same as the one above???
                                      • DolphiServiceLTD
                                        • Apr 2024
                                        • 28
                                        I made a mistake with 0 and O
                                        Do you know what kind of bios chip this laptop using ?
