Requesting BIOS for NEC VersaPro VX-2
  • Yossy
    • Nov 2022
    • 6
    • Japan
    [Manufacturer]
    NEC
    [Laptop model] There are several model-names I found on this laptop.
    VersaPro VX-2
    VKT16X-2
    PC-VKT16XZG2
    [Mother board model]
    DNLL1/L2 LA-C423P Rev:1.0
    (Picture is also attached on this thread)
    [BIOS chip model]
    Winbond 25Q128JVSQ
    (Extracted 16MB of dump data from possibly corrupted chip via CH341A is attached on this thread)
    [What I've tested so far]
    I have a bricked laptop which lights up power & charging lamp when I plug in the ac adaptor and when I push the power button the led on it changes its color to green.
    But It never turns on backlight nor any image on monitor.
    I plugged in HDMI cable trying to see if it could output any image onto external monitor, but all I could see on the external monitor was "No Signal".
    When I let the laptop sit for a while after turing on, eventually the fan starts to kick in.
    By considering these symptoms above, I think the Power-management IC is up and running, but the bios is corrupted for some reason.
    So I want to reprogram the BIOS chip.
    The manufacturer has BIOS updating software on the web, but the problem is that the program is supposed to run on Windows.
    -The download URL is as follows.
    (https://support.nec-lavie.jp/driver/...odule_no=11409)
    (The update program is also attached.)
    Currently I can't even get to see BIOS menu before loading Windows...
    If you have working BIOS data on this model, that would help me a lot.
    Thank you in advance!
  • Yossy
    • Nov 2022
    • 6
    • Japan
    Re: Requesting BIOS for NEC VersaPro VX-2
    My problem was solved. Thank you anyway.
    >Dear administrator
    I want to delete this thread but I could't find the "edit" button. Sorry to bother you.
      • 20662
      >Dear administrator
      The bios you posted might help someone.How did you solve it did you get a working bios from somewhere else
      • Yossy
        • Nov 2022
        • 6
        • Japan
        Actually I didn't solve the problem.
        Today I checked on the motherboad with DMM for further possible faults, then I found the CPU on the laptop was shorted to death.
        If I change the CPU for a working one, that might bring it back to life, but I don't have that skill nor the budget to have someone to do it.
        Therefore unfortunately there is no meaning for me to get a working BIOS now.
        As you said, this info might help someone in the future.
        • bogzky03
          • Aug 2023
          • 4
          • Philippines
          Hi All,
          I have the same request as this. hoping you can help me bypass the bios for this laptop model:
          VersaPro VX-2
          VKT16X-2
          PC-VKT16XZG2
          How do I reset this to default?
          Thank you all.
          • volinakis
            • Jan 2021
            • 2709
            • N/A
            Originally posted by bogzky03
            Hi All,
            VersaPro VX-2
            VKT16X-2
            PC-VKT16XZG2
            Thank you all.
            read the rules and post your bios dump. what means "bypass the bios"? it has password? describe your problem.
            • bogzky03
              • Aug 2023
              • 4
              • Philippines
              Apologies on this. I am not yet so well verse in bios settings.
              I recently acquired the said laptop but no HDD. upon trying to install a new HDD and trying to reformat via USB drive, I found out that cannot enter bios setup since the previous owner has set an "Admin password" or "Supervisor Password".
              Thus, I am not able to do anything unless I can remove the password. Can anyone help me on this.
              Thank you.
              • volinakis
                • Jan 2021
                • 2709
                • N/A
                Thank you.
                https://www.badcaps.net/forum/showth...t=phoenix+bios
                1. How to dump and flash
                3. Password removal by laptop brand
                • ianlouievargas
                  • Sep 2022
                  • 10
                  • Philippines
                  NEC lm750 ms-12511 bin file ....
                  good day to all please help.. i cant finf bios bin file for this model
                  • yasugogo
                    • Feb 2025
                    • JAPAN
                    Hi All,
                    Hoping you can help me bypass the bios for this laptop model:
                    VersaPro VX-2
                    VKM17XBGE
                    [BIOS chip model]
                    Winbond 25Q128JV
                    I made 02210000_PACHED.bin from 02210000.bin(Original file).
                    Booted with 02210000_PACHED.bin,it stoped with NEC Logo.
                    Help me,please.
                    How to solve it or tell me SVP.
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • jotati7062
                      11" Portable Monitor BIOS Challenge
                      by jotati7062
                      Hello everyone, i have an 11" Portable Monitor made by "Bisprico" its a cheap one but really good for a project im doing, the Monitor auto sleep after 2 minutes if no HDMI plugged, I would like to make that to 10 seconds, there is no such option in Monitor setting menu, i will provide 2 bios backups, the "ScreenBak1.bin" and "ScreenBak2.bin" on the 2nd one i only made setting menu goes away after 50 seconds from the original 10 seconds, maybe that gives idea what blocks in bios file control the auto sleep timer.
                      the bios chip is "ZB25VQ80ATIG".
                      06-19-2025, 07:27 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
